Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-01-2006, 01:59 PM   #1
maf
low pitch reroofing
My roof is about 1,480 sq. ft. and the pitch is just under 3in. for every ft. I live in Northern CA. The summers are hot but dry and we get moderate rainfall in the winter. The roof has shingles now but I'm under the impression that's not what's recomended for the pitch. What would you recommend? Modified Bitumen? Tar & Gravel? I'm clueless as to what to use and how much it could cost. I'm planning on selling in the spring and the shingles aren't doing the job (small leaks during heavy rainfall). I wanted some sort of idea before I got estimates because I'm a good target for a rip-off.
Thanks, Molly
maf is offline   Reply With Quote
Old 02-02-2006, 01:48 PM   #2
Commercial Roofing
AaronB's Avatar
low pitch reroofing
Spray polyurethane foam...no seams.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-04-2006, 02:29 AM   #3
low pitch reroofing
Thanks, Molly
If it's leaking sounds like a good time to fix it before you get to much water damage, though you probably already have some. Get as many estimates as you want if there free, and then post back your questions about estimate....
bob
bob the builder is offline   Reply With Quote
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing 21 06-18-2007 09:58 AM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing 3 03-27-2007 01:16 AM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing 5 10-26-2006 11:31 AM
Reroofing over Ten year old 3 tabbers gillaroo Roofing 15 05-02-2006 12:41 AM
Adding a gable porch to a pitch roof fjacky Building & Construction 5 08-09-2005 07:56 PM
