Loose Aluminum Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-31-2016, 11:45 AM   #1
Rewards Points: 146
Loose aluminum siding
Have a couple of loose aluminum siding slats. Bought and tried to use the Z tool with no success. Is there any adhesive that will work on aluminum to aluminum? One that doesn't require holding the pieces together for a long time? I've heard about Liquid Nail but just read that it's not good for vinyl - which, to me, is similar to aluminum?? Any suggestions would be appreciated. Thanks
Jacke is offline   Reply With Quote
Old 08-31-2016, 02:05 PM   #2
hkstroud's Avatar
Rewards Points: 2,048
Re: Loose aluminum siding
No, I have never been able to get the Zip tool to work on aluminum.
What I have done (several times) is replace the lower siding that I removed. Then nail the top piece (the one above that I did not remove) up through the bottom edge with a 8p finish nail at a 45 degree angle.
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Jacke (08-31-2016)
Old 08-31-2016, 06:41 PM   #3
Rewards Points: 14,026
Post a picture of your issue.
Somethings wrong behind that wall if the siding is coming unlocked.
No way would I be using a steel finish nail to try and fix aluminum siding.
#1, Steel is going to rust.
#2, To small a head.
#3, Aluminum siding expands and contracts a lot and it will not be able to move.
#4, Steel in direct contact with aluminum will cause the aluminum to corrode.
Jacke (09-01-2016)
Old 09-01-2016, 08:18 AM   #4
craig11152's Avatar
Rewards Points: 298
Unfortunately the zip tool isn't made for aluminum, only vinyl. Vinyl has the flexibility that aluminum doesn't.
How many pieces would you need to remove above to get to the loose pieces? That may be the safest, surest way but it could be a lot of work if you have to remove most of a wall.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
Jacke (09-01-2016)
Old 09-01-2016, 10:08 AM   #5
Rewards Points: 146
no glue/adhesive that works on aluminum?
Old 09-01-2016, 12:06 PM   #6
craig11152's Avatar
Rewards Points: 298
probably but as Joe pointed out aluminum and vinyl siding both are properly applied with expansion and contraction in mind. That is why the nailing flange is wide and you aren't supposed to nail tight. Its all about the product being able to move. If you glued it maybe you wouldn't have a big problem if it was on a north side that never saw any sun but its still a big maybe.
Jacke (09-01-2016)
Old 09-02-2016, 05:32 AM   #7
Not sure what exactly you plan on gluing.
Here's a picture of what a siding lock looks like, to lock the siding needs to be slid up then nailed, if it's still nailed to the wall it can not be lifted to lock.
Yes I know this is a picture of vinyl siding lock but aluminum and vinyl siding installs and locks about the same.
https://www.google.com/search?q=alum...qdIN-u8kBhM%3A
Jacke (09-02-2016)
Old 09-02-2016, 08:14 AM   #8
Rewards Points: 146
This was helpful. Going to try to use the Z Tool again to get the slat to lock onto the ledge.
Old 09-02-2016, 01:47 PM   #9
hkstroud's Avatar
Let us know how that goes.
If you really want to turn this 30 minute task into a 3 day job.
Get some aluminum nails with a small head.
Get out your oscillating tool and cut a 3/4" slat or slit in the bottom edge of the top piece where you want to nail. Then nail up at a 45 degree angle through the slit. That should allow the siding to expand and contract..
Jacke (09-02-2016)
Old 09-02-2016, 05:07 PM   #10
Rewards Points: 146
Again I couldn't get the tool to work as it's suppose to - ugh. Thanks for the instructions that sound reasonable but... I'm not sure if I am capable of doing all of this. Might have to hire someone. Thanks for the idea though.
Old 09-02-2016, 06:05 PM   #11
hkstroud's Avatar
The oscillating tool is very easy to use. Cheap also if purchased from Harbor Freight. About $20. However you will need to purchase different blades. Harbor Freight blades are not worth taking out the store. Just hold the blade against the bottom of the siding and it will cut a slot through. The tool cuts by vibrating the blade back and forth a small distance. Very easy to control.
Old 09-02-2016, 07:18 PM   #12
All these suggestions and still not one picture of what your dealing with.
NO way would I be cutting that siding to get it to move up!!!
Jacke (09-03-2016)
Old 09-03-2016, 09:15 AM   #13
Rewards Points: 146
Didn't know a picture would help - getting one now and will figure out how to upload. Thanks
Old 09-07-2016, 09:55 AM   #14
Rewards Points: 146
Not sure if this is how one does it but I've posted a picture in "my album". Hoping all can access this album. Thanks
Old 09-07-2016, 11:59 AM   #15
ZTMAN's Avatar
Rewards Points: 482
Hit the loose pieces with some Skiaflex 221. If the pic in your album is the only issue, you can run a sheet metal screw from up underneath as well
ZTMAN is online now   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
Jacke (09-08-2016)
Installing Full Frame Window - Existing Aluminum Siding walked Windows and Doors 7 03-20-2014 01:51 PM
Repainting aluminum siding - 2 part question jmorc2003 Painting 3 07-29-2013 09:13 PM
Wood siding under aluminum bryanp22 Roofing/Siding 2 06-30-2013 10:49 PM
vinyl siding over aluminum siding abbydaisy08 Building & Construction 8 11-02-2010 11:27 PM
Aluminum siding miami vice 25 Building & Construction 2 05-22-2007 03:13 PM
