Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 11-15-2012, 07:21 PM   #1
Looking for opinions on shingling on A/C unit with cricket
If all was well With the proper flashing/lead/cricket how would you as a professional roofer go about shingling this A/C unit (Cutting the main roof)
in Detail Which Shingles would you put on in Order
which position would the shingle be placed to meet its proper spot with the flashing
were talking about at the Top corner of this A/C unit to meet into the cricket to create your Weave then to continue up the Cricket cutting the main in the end. You would have your first piece of step flashing on top the lead at the bottom of the cricket
vandel777 is offline   Reply With Quote
Old 11-15-2012, 08:08 PM   #2
Edit:
Sorry if confused
"You would have your first piece of step flashing on top the lead at the bottom of the cricket"
Meant to say "first piece of lead on top the lead for the 2 corner pieces or if u wanted just the cricket corner piece with the side corner as step flashing roofing varies :D
Old 11-16-2012, 10:26 AM   #3
Roofmaster
Go to the NRCA Steep roofing manual and get the correct detail or hire a professional roofing contractor. From what you are showing it is hard to even tell what you are trying to do.
jagans is online now   Reply With Quote
The Following User Says Thank You to jagans For This Useful Post:
joecaption (11-16-2012)
Old 11-16-2012, 10:35 AM   #4
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Impossible to describe in words. Though it would be no different from a chimney flashing. Contact the NRCA at www.nrca.net and ask them for detail No. 3.6.4, 3.6.4.1, & 3.6.4.2 These are from the NRCA 5th Edition manual.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
Old carrier unit trouble hdbg62 HVAC 18 06-29-2011 09:57 PM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 08:50 PM
Replacing inside air control unit - have to replace outside as well? yalej HVAC 2 04-29-2009 12:46 PM
