Looking For Advice On Rafter Size For Shed..... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-28-2011, 11:56 AM   #1
mlf
Looking for advice on rafter size for shed.....
I'm building a 12'X16' shed. The width is 12', so my rafter span would be 6', minus half my ridge board (3/4"). So the total span will be a little less than 6'. The roof pitch will be either 6/12 or 7/12. The rafters are going to be spaced 16" OC. I plan to use 3/8" plywood for the roof sheeting and asphalt shingles. The plans I have call for 2X4 rafters. I was just wondering will those be sufficient, or should I go with 2X6? I live in Alabama, so snow is not an issue.
mlf is offline   Reply With Quote
Old 06-28-2011, 06:09 PM   #2
Rewards Points: 1,016
2x4 rafter will be ok.
____________
Vince
Old 06-28-2011, 06:18 PM   #3
PRO
MLF,
The 2x4's will be sufficent but if your looking for longevity, 2x6's are the way to go.
BrandConst is offline   Reply With Quote
Old 06-28-2011, 06:22 PM   #4
kwikfishron's Avatar
Rewards Points: 186
2x4 will work but I’d go 2x6 24” OC just to have more meat for a seat cut and overhang.
The 3/8” plywood is a bad idea, go at least ” , 5/8” preferably.
kwikfishron is online now   Reply With Quote
Old 06-28-2011, 06:31 PM   #5
I built a 16x26 long garage in 1977 or so, with a stick built roof of 2x4 rafters across the 16 width, as recommended by my all his life carpenter father - still standing just fine. I would use 1/2" plywood with clips - as you are on 16" centers.
____________
Vince
Old 06-29-2011, 09:00 AM   #6
mlf
Thanks for the responses. I believe I am going to go with the 2X6's, but on 24" centers, and 1/2" plywood. After cutting out the birdcage, the 2X4's would have very little left to support a 1 foot overhang.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
need some rafter help feralfreak Carpentry 5 07-30-2008 07:48 AM
