-   -   Looking for advice on rafter size for shed..... (http://www.diychatroom.com/f9/looking-advice-rafter-size-shed-109053/)
mlf 06-28-2011 10:56 AM
I'm building a 12'X16' shed. The width is 12', so my rafter span would be 6', minus half my ridge board (3/4"). So the total span will be a little less than 6'. The roof pitch will be either 6/12 or 7/12. The rafters are going to be spaced 16" OC. I plan to use 3/8" plywood for the roof sheeting and asphalt shingles. The plans I have call for 2X4 rafters. I was just wondering will those be sufficient, or should I go with 2X6? I live in Alabama, so snow is not an issue.
vsheetz 06-28-2011 05:09 PM
2x4 rafter will be ok.
BrandConst 06-28-2011 05:18 PM
MLF,
The 2x4's will be sufficent but if your looking for longevity, 2x6's are the way to go.
kwikfishron 06-28-2011 05:22 PM
199 Attachment(s)
2x4 will work but I’d go 2x6 24” OC just to have more meat for a seat cut and overhang.
The 3/8” plywood is a bad idea, go at least ” , 5/8” preferably.
vsheetz 06-28-2011 05:31 PM
I built a 16x26 long garage in 1977 or so, with a stick built roof of 2x4 rafters across the 16 width, as recommended by my all his life carpenter father - still standing just fine. I would use 1/2" plywood with clips - as you are on 16" centers.
mlf 06-29-2011 08:00 AM
Thanks for the responses. I believe I am going to go with the 2X6's, but on 24" centers, and 1/2" plywood. After cutting out the birdcage, the 2X4's would have very little left to support a 1 foot overhang.
