Leaky Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-14-2013, 10:06 AM   #1
Leaky roof
Hello,
New roof as of this fall and have a leak see picture. any thoughts? I know this is where it is leaking for sure. spoke to the contractor and he is telling me it is leaking because the facsia is missing?
Thank you
yooper49 is offline   Reply With Quote
Old 03-14-2013, 10:12 AM   #2
Rewards Points: 13,274
That and it's flashed wrong.
That flashing needed to run all the way to the end of the fashia.
Old 03-14-2013, 10:20 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
and I would like to see the valley extended a tiny bit as well.
Given the snow and ice accumulation there, that may be a problematic spot in the future.
Old 03-14-2013, 10:21 AM   #4
Thank you
Thank you!!
That is what I was thinking
For my knowledge how would you make that correct?
Again Thanks
Thad
Old 03-14-2013, 11:01 AM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Yes, those steps have to extend behind the fascia to a point below the soffit itself. I always try to cut the fascia loose and put my step flashing behind the wood itself.
In addition, the vally is supposed to come out 4" minimum to throw water out from the fascia.
i have concerns about the amount of ice I see farther under there. That may be coming from farther up.
tinner666 is offline   Reply With Quote
Old 03-14-2013, 03:15 PM   #6
747
registered
747's Avatar
Rewards Points: 534
That first pic is funny
747 is offline   Reply With Quote
Old 03-14-2013, 07:36 PM   #7
O/P please go back and add your location to your profile, just go to Quick links to add it.
It would be interesting to remove that soffit and see what they did under it.
Did they at least use Storm and Ice Shield on the lower part of the roof?
Old 03-14-2013, 09:45 PM   #8
Doing This Way Too Long
Rewards Points: 532
Is that ice or caulk all over that transition?
OldNBroken is offline   Reply With Quote
Old 03-15-2013, 06:29 AM   #9
Roofmaster
Rewards Points: 2,172
Can you please post a wider shot of this area so we can see how this all comes together? Take a couple so we can get the whole picture. It looks like you have very little slope to drain in the valley above if I am seeing this correctly.
Thanks, oh and yes location means a lot.
Leaky Roof...Just How Bad? Scully Roofing/Siding 18 03-01-2012 01:06 AM
Leaky Roof Deck! Steak Roofing/Siding 3 01-07-2011 06:29 PM
Leaky roof? rockets Roofing/Siding 3 12-07-2010 12:40 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Leaky Roof Repairs jfm617 Roofing/Siding 1 07-03-2007 12:43 PM
