-   -   Leaky roof (http://www.diychatroom.com/f9/leaky-roof-174493/)
yooper49 03-14-2013 09:06 AM
Leaky roof
1 Attachment(s)
Hello,
New roof as of this fall and have a leak see picture. any thoughts? I know this is where it is leaking for sure. spoke to the contractor and he is telling me it is leaking because the facsia is missing?
Thank you
ThadAttachment 67316
joecaption 03-14-2013 09:12 AM
That and it's flashed wrong.
That flashing needed to run all the way to the end of the fashia.
Windows on Wash 03-14-2013 09:20 AM
+1
and I would like to see the valley extended a tiny bit as well.
Given the snow and ice accumulation there, that may be a problematic spot in the future.
yooper49 03-14-2013 09:21 AM
Thank you
Thank you!!
That is what I was thinking
For my knowledge how would you make that correct?
Again Thanks
:thumbup:Thad
tinner666 03-14-2013 10:01 AM
1 Attachment(s)
Yes, those steps have to extend behind the fascia to a point below the soffit itself. I always try to cut the fascia loose and put my step flashing behind the wood itself.
In addition, the vally is supposed to come out 4" minimum to throw water out from the fascia.
i have concerns about the amount of ice I see farther under there. That may be coming from farther up.:(
747 03-14-2013 02:15 PM
That first pic is funny:laughing:
joecaption 03-14-2013 06:36 PM
O/P please go back and add your location to your profile, just go to Quick links to add it.
It would be interesting to remove that soffit and see what they did under it.
Did they at least use Storm and Ice Shield on the lower part of the roof?
OldNBroken 03-14-2013 08:45 PM
Is that ice or caulk all over that transition?
jagans 03-15-2013 05:29 AM
Can you please post a wider shot of this area so we can see how this all comes together? Take a couple so we can get the whole picture. It looks like you have very little slope to drain in the valley above if I am seeing this correctly.
Thanks, oh and yes location means a lot.
