Leaks Around Chimney After New Roof Was Put On - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-31-2008, 02:32 PM   #16
Any idea how much the sealer should cost me?
I personally thought that the problem was with the new flashings as the roof never leaked before this new roof was put on, but they assured me that's not the problem.
Thanks for taking the time to write.
proofer is offline   Reply With Quote
Old 03-31-2008, 03:36 PM   #17
Product Description:
http://www.chimneysaver.com/
Price on e-bay:
http://cgi.ebay.com/CHIMNEY-SAVER-WA...QQcmdZViewItem
Another good Chimney Supply House:
http://www.copperfield.com/#
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-01-2008, 06:51 PM   #18
Thanks, Ed, for those links for the sealer.
To recap: I have to have some work done on my chimney: (1) tuck point it and (2) a lot of the mortar replaced on the outside blocks on the top part of the chimney about 8 rows up from the top. This is to repair the leaking coming into the house down both sides of the brick fireplace walls. They also recommended that I have it sealed. Question: Should the sealing be done right after this masonry work is done, or should it wait a few months after this repair work is done in order to allow time for the mortar to cure?
Old 04-01-2008, 07:27 PM   #19
I can't recall what is recommended by the Masonry books I have read right now, but if it is dry and warm weather, I would wait at least 48 hours if that is a concern.
Now I have to look something else up, just to be certain that the advice is accurate.
Ed
Old 04-04-2008, 09:57 PM   #20
the roofing god's Avatar
Send a message via MSN to the roofing god
you need to wait longer,cement takes a very long time to dry,anywhere from 45-60 days would be more accurate,so moisture doesn`t affect any sealers applied
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 04-05-2008, 09:11 AM   #21
I'm glad you reminded me to look that up. I will check out my masonry books when I get to the office later this afternoon.
Thanks. I do not recall them saying to wait that long, but I will find out.
Ed
Old 04-13-2008, 07:09 PM   #22
What would you recommend my using to fix the staining on the interior brick walls that the rain caused? The mortar has stained quite a bit (white and yellow).
Old 04-13-2008, 07:15 PM   #23
10% sulfuric acid and 90% water.
Have PLENTY of ventilation.
Rough bristle brush to rub the stains with.
Safety goggles for your eyes.
Cover everyting that can possibly be splattered with a very heavy rubber tarp material.
Try just soap and hot water first though, plus that will show you how much splatter there wil be.
I actually think you should repost this portion of the question in the masonry section, especially for safety reasons.
Ed
Old 04-13-2008, 07:27 PM   #24
Thanks, Ed, for the quick reply. I think I'll try the soap and water first as you recommended, seeing that that's less invasive than sulfuric acid. But if I needed to buy sulfuric acid, where would I get the stuff.
Someone mentioned using vinegar. Do you think that would work?
Old 04-13-2008, 09:18 PM   #25
Home Deopt sells Sulfuric acid.
Try anything else first. Vinegar, ammonia, clorox, 409, Simple Green, Fantastic, etc...
The masons should have the best advice on this part.
Ed
Old 04-22-2008, 01:31 AM   #26
Originally Posted by proofer View Post
We had a new roof put on (tear-down) in December. We've recently had two good rains, and there is leaking coming in at the front and back of the chimney and running down the face of both brick walls inside the house. Inside the house just below the ceiling, the water comes in about 5 feet across (on each of the brick walls) I think it could be the flashings that need fixed. The roofer says it could be the mortar. Hopefully it's the flashings and it will be covered under warranty. If it is the mortar, about how much would that cost if done by the roofer? Or is it something that I could do myself? I do have half a bag of mortar that the roofers left because when the roofers came out and installed the new roof, we needed a new chimney cap.
I hope your roofer mixed some of that acrylic stuff with his mortar as new mortar does not stick to old very well without it. You can repoint your own chimney & it could be that the counter flashings were loose & installing new roofdeck flashings were enough movement to create a problem. Also lots of roofers try to wrap the flashings around your chimney or skylights or don't know the proper way to snip then fold the sides with a 3" overhang.
Dale Chomechko(DC Roofing Inc)
Dale Chomechko is offline   Reply With Quote
Metal roof leaks Cowchip500 Roofing/Siding 8 10-22-2012 11:31 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 10:27 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
