-   -   Leaking vent pipe? (http://www.diychatroom.com/f9/leaking-vent-pipe-69708/)
emylime 04-23-2010 10:46 PM
Leaking vent pipe?
We have had continual problems with wet drywall near our shower.
Finally just tiled it to keep shower spray off.
Then the nearby door molding started to swell with water.
called a plumber. He attached a meter to the house and said we don't have any foundation leaks. Took off the shower handle and looked at the pipe leading to the shower head inside the wall. No leak there either. He suggested that it was a leaking vent pipe.
Called a roofer. He went up on the roof, looked at the area, found a loose nail. Hammered it in and caulked. This was on a rainy day, so it was easy for him to see the leak. He says the roof is in good shape, and does not need to be replaced, looked around for loose shingles and other caulking and could not find any. I figure that seeing as he makes his living by doing new roofs I don't need a new roof.
Now it rained all yesterday, and the door frame molding is wet again. Any other possibilities? Should I go up and look around the vent pipe? Call the roofer back? Call another roofer?
Scuba_Dave 04-23-2010 11:37 PM
Where is the door ?
Exterior door ?
AaronB 04-23-2010 11:44 PM
Pics help a lot... from inside, the locale of the pipe in relation to the wet door, and of the roof taking into account the location of all said items.
emylime 04-24-2010 02:04 PM
Pictures of the wet molding, shower and vent pipe
3 Attachment(s)
The first picture shows the wet molding on the interior door
The second picture shows it's relation to the shower and window
the third picture shows the vent pipe in relation to the window.
waterman1971 04-24-2010 02:36 PM
I would remove the door casing to look for wetness higher up.
AaronB 04-24-2010 03:02 PM
The vent pipe appears to run up the outside wall if those are that same two windows. You might be leaking from the shower as well.
emylime 04-24-2010 03:46 PM
it looks like either way taking apart the door casing will give more info?
seeyou 04-24-2010 07:21 PM
Check the condition of the neoprene gasket on the WV boot.
I've also found dry PVC joints in the attic. How they passed a pressure test is beyond me.
emylime 04-24-2010 07:50 PM
I'm afraid I don't know what a WV boot is, nor the neo??
seeyou 04-24-2010 07:55 PM
WV boot = Waste Vent boot. The flashing at the roof line around your waste vent pipe. The neoprene gasket hugs the pipe and keeps water from flowing on the outside of the pipe. The gasket is degradable by UV rays and will crack in time allowing water to run in down the outside of the pipe.
edit: The way to test for an unglued joint in the waste vent line is to stick a garden hose in the vent pipe and let it run. If you get the same leakage that you're seeing during rain, that's what the problem is.
emylime 04-27-2010 04:09 PM
Took apart the door casing. The wetness is about 8 inches up. Took off the molding. The wetness extends to the shower and about 2 inches beyond on behind the shower. Tomorrow my friend and I will knock a hole in the wall and see what there is to see. I really doubt it is the vent pipe at this point. Why would a vent pipe only leak so close to the ground? So this probably doesn't belong in roofing anymore. My guess that it is the shower. One of two options the first being that the plumber didn't know what he was doing and there is a leaking pipe. The second guess is that the plastic base of the shower has a small hole.
AaronB 04-27-2010 04:29 PM
OR.... could be that your shower door frame is not sealed to the base anymore...
waterman1971 04-28-2010 02:47 PM
Congrats you are narrowing it down.
