leaking skylight?
Is it a vaulted/cathedral ceiling style or an open attic and a standard ceiling?
The reason I ask, is that the rafter bay(s) that terminate and originate from both the bottom and top of the skylight have effectively blocked a free flowage of air, which along with being super-heated also contains humidity, which cannot be exhausted and will collect and create condensation leak stains to the interior.
Also, since you did not name the type or age of the skylight, that can not be diagnosed, but some skylight kits, such as Velux, contain a superior flashing kit than other brands do.
Further, the seal between the 2-3 layers of either plexi-glass or tempered glass may be broken allowing condensation to collect.
A water test with a continuously running hose laying on the roof shingles several feet above the skylight for about an hour would probably determine if the base flashings are the cause of the leak and if so, then a proper repair and possible removal and resetting or full replacement may be called for.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
