Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-06-2007, 09:50 PM   #1
Leaking roof -recommend a roof coating?
My roof is a very low pitch roof with "roll roofing". It is about 15 years old. There are cracks at the seams, and I can't I can't see any obvious leaks. But have plenty of ceiling staining. I am assuming small holes where "ponding" occurs.
I am looking for a recommendation on a roof coating. I notice that the "elastometric" brands recommend a "primer". the primer sells at about 3 times the price of the coatings, or about $150.00 for a 5 gal pail. I can't find a good estimate of coverage on the primers. The coatings seem to run $50-60 for a 5 gallon pail. The roof is about 2800 feet.
I would like to keep the roof white, but I may end up with black asphalt based.
Any experience or brand recommendations out there?
Faust is offline   Reply With Quote
Old 07-07-2007, 07:18 AM   #2
Does this roof area face south? (direct sunlight)
What type of climate are you in?
What is the dimension of the roof? (10 x 20 , 20 x 20...)
redline is offline   Reply With Quote
Old 07-07-2007, 09:04 AM   #3
Since it is a nearly flat roof, I guess it faces in all directions.
Climate? Northeast, USA
The size is 40 X 70.
Old 07-07-2007, 01:57 PM   #4
Is this a ranch style house?
Can you post a photo of the roof?
Old 07-11-2007, 01:18 PM   #5
yes, hot tar roofing its cheap and leak safe contact b2b roofing at 910-770-3843
b@b roofing is offline   Reply With Quote
Old 07-12-2007, 11:09 PM   #6
Here are pictures (click'em) of the roof and what I thnk is one of the leaks.
<center>
<a href="http://img.photobucket.com/albums/v1...F/DSCN2081.jpg" target="_blank">
<img src="<A href="http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2081.jpg"></a">http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2081.jpg"></a>
<a href="http://img.photobucket.com/albums/v1...F/DSCN2080.jpg" target="_blank">
<img src="<A href="http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2080.jpg"></a">http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2080.jpg"></a>
</center>
I have been looking into Kool Seal products. With a double coat of their primer and a double coating of their roof coating, a rubber roof starts to look reasonable. Too bad, it looks like they have a good product.
leaking tar and gravel roof meleis Roofing 9 01-05-2008 11:27 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Mysterious leaking roof... Suggestions? AlbrightPM General Discussion 8 10-30-2006 11:47 PM
Help- leaking flat roof, alum?metal? xoroniox Roofing 1 04-24-2006 12:03 PM
Reflective Coating on Flat Roof MelindaA Roofing 3 01-05-2006 06:08 AM
