-   -   Leaking roof -recommend a roof coating? (http://www.diychatroom.com/f9/leaking-roof-recommend-roof-coating-9690/)
Faust 07-06-2007 09:50 PM
My roof is a very low pitch roof with "roll roofing". It is about 15 years old. There are cracks at the seams, and I can't I can't see any obvious leaks. But have plenty of ceiling staining. I am assuming small holes where "ponding" occurs.
I am looking for a recommendation on a roof coating. I notice that the "elastometric" brands recommend a "primer". the primer sells at about 3 times the price of the coatings, or about $150.00 for a 5 gal pail. I can't find a good estimate of coverage on the primers. The coatings seem to run $50-60 for a 5 gallon pail. The roof is about 2800 feet.
I would like to keep the roof white, but I may end up with black asphalt based.
Any experience or brand recommendations out there?
redline 07-07-2007 07:18 AM
Does this roof area face south? (direct sunlight)
What type of climate are you in?
What is the dimension of the roof? (10 x 20 , 20 x 20...)
Faust 07-07-2007 09:04 AM
Since it is a nearly flat roof, I guess it faces in all directions.
Climate? Northeast, USA
The size is 40 X 70.
redline 07-07-2007 01:57 PM
Is this a ranch style house?
Can you post a photo of the roof?
b@b roofing 07-11-2007 01:18 PM
yes, hot tar roofing its cheap and leak safe contact b2b roofing at 910-770-3843
Faust 07-12-2007 11:09 PM
Here are pictures (click'em) of the roof and what I thnk is one of the leaks.
<center>
<a href="http://img.photobucket.com/albums/v1...F/DSCN2081.jpg" target="_blank">
<img src="<A href="http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2081.jpg"></a">http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2081.jpg"></a>
<a href="http://img.photobucket.com/albums/v1...F/DSCN2080.jpg" target="_blank">
<img src="<A href="http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2080.jpg"></a">http://img.photobucket.com/albums/v141/TWFaust/ROOF/th_DSCN2080.jpg"></a>
</center>
I have been looking into Kool Seal products. With a double coat of their primer and a double coating of their roof coating, a rubber roof starts to look reasonable. Too bad, it looks like they have a good product.
