[Leaking Roof] How Do I Remove Old Mastic/elastomeric Coating? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-26-2013, 06:34 PM   #1
So I purchased a gallon of Henrys Masic and I want to apply it to my two leaking penetrations at my home...
When trying to remove the old Mastic its pretty solid.
1. How much of the original mastic do I need to remove?
2. Should I take a hammer and chisel to it or is there a chemical I can use to soften old mastic.
Photos
http://imgur.com/a/Oo9Z2
plasticslug is offline   Reply With Quote
Old 01-26-2013, 07:22 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Pix would help. mastic usually lead to leaking issues. Maybe it all needs to be removed and the penetrations need to be flashed instead.
tinner666 is offline   Reply With Quote
Old 01-26-2013, 07:29 PM   #3
Rewards Points: 13,256
Is this for real?
You need to now remove all of that and do it over right.
That dish cable and bracket should never have been mounted on the roof or run down through the roof like that!!!
http://www.bing.com/images/search?q=...lectedIndex=60
Old 01-26-2013, 11:55 PM   #4
Metal Roofing
Rewards Points: 600
For god sake dont do that, have it flashed properly. It looks like an AC line to me, but either way it needs a flashing not what you are proposing.
AndyWRS is offline   Reply With Quote
Old 01-27-2013, 12:01 AM   #5
I've been in home repair for over 40 years and have not use a gal. of roofing tar in my whole life, take it back and just buy one caulking tube of it to put under the new flashings.
Old 01-28-2013, 01:06 PM   #6
Roofmaster
Rewards Points: 2,172
You need a Portals Plus penetration flashing, not roof cement, and you need a roofer that understands headlap, and that a properly flashed penetration on a steep roof requires no roof cement. Google Portals Plus.
Old 01-30-2013, 10:22 PM   #7
Quality Exteriors of CT
QualityRoofing's Avatar
Wow, please call a roofer and have them fix this. Putting goop over the problem will only stop the leak temporarily, it will eventually crack and leak again. Call a roofer and have them install flashing on the pipe boot, I'm not sure what the other extrusion on the roof is, pretty sure it doesn't belong on he roof thou.
QualityRoofing is offline   Reply With Quote
Old 01-31-2013, 02:45 AM   #8
Roofmaster
What you have is roofing or flashing cement, coated with aluminum coating on a seal tite cable and a thermostat wire.
A really good way to handle this is to put a 3 inch PVC pipe up through the roof, and strap it to the top chord of the truss or rafter and an additional brace with Ubolts. Install a rubber All-Vent on the pipe, then glue a return bend or two street Els on the end of the pipe so the end points down. Run your lines through, and foam the end of the pipe.
How many coats of elastomeric coating do we need? bayles Roofing/Siding 5 10-08-2010 02:47 PM
