Leaking Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-28-2011, 06:46 PM   #16
MJW
Originally Posted by kwikfishron View Post
After the step flashing is installed then a weather barrier and then your siding cover it.
My bet is the flashing is fine and so is the roof. The siders or framers probably have the housewrap behind the flashing. This was often done because they would build the walls and wrap them right away, then build the garage roof that meets it. Another thing, is maybe there is no house wrap at all. This wasn't always code.
MJW is offline   Reply With Quote
Old 03-28-2011, 07:03 PM   #17
Rewards Points: 2,240
MJW
What!??
The roofers are supposed to slice the "house-wrap" and tuck the step
flashing underneath it!
Aren't they!?
We do that ALL the time in "Never-Never Land"!!
Ha, Ha, Ha !
Regards!
RF
rossfingal is offline   Reply With Quote
Old 03-28-2011, 07:07 PM   #18
All!
My bet is, that it's the "usual" conglomeration of all or some of the problems
listed above.
Oh Boy!
RF
Old 03-28-2011, 08:16 PM   #19
MJW
Originally Posted by rossfingal View Post
MJW
What!??
Aren't they!?
Ha, Ha, Ha !
Regards!
RF
Yes, you are right. When the house was originally built, you are correct. Which is what this appears to be.
We haven't done a new house in years, so I am geared more toward replacement lately.
Usually we do the roof and the siding, so then everything is new, properly flashed, and papered.
That siding and roof should be replaced soon anyways. Hopefully the OP gets a good installer and better materials.
The Following User Says Thank You to MJW For This Useful Post:
rossfingal (03-29-2011)
Fixing a leaking concrete roof akankoh Roofing/Siding 7 04-28-2010 10:16 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
New 1yr Townhome with Leaking Roof! sijunk Roofing/Siding 9 08-08-2008 03:50 PM
Supposedly 'new' roof is leaking beejay Roofing/Siding 3 03-06-2007 10:55 AM
