#1 |
leaking roof
I have an enclosed aluminum patio and when it rains hard, the roof leaks through the seams. I have tried caulking, but it doesn't work. Does anyone have any ideas as to what can be done?
#2 |
RFN-4A-LVN
leaking roof
What type of material is it? Corrugated? If possible post a pic.That will assist in insuring that you are pointed to the right product to use.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
leaking roof
What type of caulk did you use? A picture would help alot
Jadon http://www.charactercraftsmen.com/roofing |
#4 | |
leaking roofQuote:
#5 | |
leaking roofQuote:
www.springtxroofingcontractors.com |
| Display Modes | |
| Fixing a leaking concrete roof | akankoh | Roofing/Siding | 7 | 04-28-2010 11:16 AM |
| Putting a new flat roof on a 3600 sf home | Jean3 | Off Topic | 2 | 04-09-2010 01:35 AM |
| The moving Ice Dams after using a roof rake ?? | Canufixit | Roofing/Siding | 9 | 02-05-2009 08:33 PM |
| New 1yr Townhome with Leaking Roof! | sijunk | Roofing/Siding | 9 | 08-08-2008 04:50 PM |
| Supposedly 'new' roof is leaking | beejay | Roofing/Siding | 3 | 03-06-2007 11:55 AM |
