Leaking Interiors From Home Additions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-26-2013, 05:45 PM   #1
Leaking Interiors from Home Additions
We have an 1890's Tidewater farmhouse clad in wood siding. Several years ago we added on in three places around the original house. When we get very hard rains the water passes through the original siding, down the backside of the siding and into the rooms near where the new roofs meet the walls. (seams) I suppose originally that the rain did the same, except it traveled downward to the ground.
We have had carpenters caulk the seams and on the underside of each piece of siding to no avail. My husband thinks we should cover with vinyl, but it seems that there could be another solution. I was thinking that maybe something could be put under the siding in those areas to keep out the leaks.
Anyone???Thank you!!!
palmerbeachgirl is offline   Reply With Quote
Old 08-26-2013, 06:28 PM   #2
Framing Contractor
Rewards Points: 112
Metal flashing should have been used there. Caulking is not a good choice for areas like that. The wood siding can be carefully removed and reinstalled after proper flashing is installed. If you have any pics we could get a better idea of what you have.
sixeightten is offline   Reply With Quote
The Following 2 Users Say Thank You to sixeightten For This Useful Post:
kwikfishron (08-26-2013), oh'mike (08-26-2013)
Old 08-26-2013, 06:45 PM   #3
Rewards Points: 13,270
When you say Tidewater do you mean as in the Chesapeake Bay?
Old 08-26-2013, 06:45 PM   #4
Rewards Points: 5,974
Any thing would be better than vinyl siding.
Old 08-26-2013, 07:23 PM   #5
Rewards Points: 154
Caulk is not meant to be a first line of defense against water intrusion. It was designed to seal small gaps water passes as it is guided down and away by proper flashing so it doesn't get diverted along the way. You could probably empty the caulk aisle at Home Depot and still not fix it. The siding was not installed properly and someone who knows that stuff needs to look at it and tell you what's going on. A siding guy, not a handy man or jack of all trades. And some seams and gaps are not meant to be caulked on siding. They're there to let it breath and naturally drain moisture. When you put sealant in areas where the manufacturer doesn't call for you can make the problem worse by holding moisture inside it and causing more rot.
eharri3 is offline   Reply With Quote
The Following User Says Thank You to eharri3 For This Useful Post:
woodworkbykirk (08-26-2013)
Old 08-26-2013, 08:04 PM   #6
Rewards Points: 692
Well said
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 08-26-2013, 09:45 PM   #7
Roofmaster
Rewards Points: 2,172
Frankly,
Leaks are usually exacerbated with the application of sealant to an improperly flashed condition. What kind of wood siding are we talking about? Im not quite understanding the concept of water flowing down the back of your siding. It should be flowing down the face of your siding, and you should have drip caps at openings, and base and counter flashings to redirect water out to the surface of your siding.
Old 08-26-2013, 09:52 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
sounds like the siding was nailed directly to the studs.. theres no sheathing over the studs or felt paper
woodworkbykirk is offline   Reply With Quote
Old 08-26-2013, 10:41 PM   #9
Roofmaster
In that case I would remove the siding, throw in outlets where you need them and plumbing, Insulate it, sheathe it, black it in and reinstall or replace the siding. Might just as well replace the windows if they suck too.
Big job, but then you would have something.
Old 08-27-2013, 09:20 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
Be prepared for an expense of some undertaking but as mentioned above, you will need to fix it and fix it right.
Tags
leaks , wood siding
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 09:03 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General DIY Discussions 2 11-14-2008 08:43 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
