Leaking Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-15-2008, 10:58 PM   #16
the roofing god's Avatar
Send a message via MSN to the roofing god
FOR THIS AREA;
I would prefer to cut that 4x4 area out,use a sawzall with a long blade to get under the cricket area,torch new pieces in under the cricket,and then torch the lap from the end of the cricket onto the pieces you put underneath,please hire a professional to do it correctly,although it is a small repair ,it is necessary to be cautious with a flame in that area---or you can do the same thing only use the adhesive rolled bitumen product,and then trowel the pieces in with the rubberized sbs sealant(same as the mb,except mfgr,you could also use karnak ultra for the same results)
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
large leaking tar flat roof erbilliards Roofing/Siding 2 03-16-2008 11:59 AM
tar and grvel flat roof leaking alexbadiuk Roofing/Siding 4 01-11-2008 01:29 PM
Leaking Cement Flat Roof surritab Roofing/Siding 1 01-31-2007 11:48 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Help- leaking flat roof, alum?metal? xoroniox Roofing/Siding 1 04-24-2006 11:03 AM
