Leaking Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-05-2005, 05:38 PM   #1
Leaking flashing
Hi all. New guy here. I have a question about who the right repair person would be to contact regarding leaky chimney flashing? Roofer or chimney repair?
Colin is offline   Reply With Quote
Old 06-06-2005, 01:23 AM   #2
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
If your positive it's just the flashing a trusted local handyman might be your best bet, but you asked about a roofer or a chimney man, so I would advise the roofer, he'll probably be cheaper than the chimney guy.
Hope that helps out & welcome to the forums! :D
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 06-07-2005, 06:54 PM   #3
Thanks housedocs. I'm quite sure it's the flashing. I redone the roof about 4 years ago and the flashing at the time was an issue. I have since noticed a slight stream of water that is running down the chimney from under the soffit.
Old 06-26-2005, 06:39 AM   #4
Commercial Roofing
AaronB's Avatar
an experienced ROOFER (not any toothless shingler) should be able to take care of the chimney flashings. I would not trust any old handyman to work on your roof, as he is most likely underinsured and underqualified. Look for a reputable roofing company and expect to pay more than a handyman for their expertise and professionalism.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 06-28-2005, 07:24 AM   #5
Any good carpenter or roofer could fix your roof problem.
A general handyman though I would not enlist for such a project.
CarpenterDon is offline   Reply With Quote
Old 06-28-2005, 08:49 AM   #6
Commercial Roofing
AaronB's Avatar
I finally found a carpenter that has the personal strength to admit that he knows jack about roofing. AMEN!
Carpenters should stick to building and leave the waterproofing to the roofers. I have repair countless roofs installed by carpenters.
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 11:31 PM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 11:27 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
Flashing? sflamedic Roofing/Siding 1 11-15-2006 08:23 PM
Flashing problems Slave Building & Construction 3 11-16-2005 04:56 PM
