-   -   Leaking flashing (http://www.diychatroom.com/f9/leaking-flashing-687/)
Colin 06-05-2005 04:38 PM
Leaking flashing
Hi all. New guy here. I have a question about who the right repair person would be to contact regarding leaky chimney flashing? Roofer or chimney repair?
housedocs 06-06-2005 12:23 AM
If your positive it's just the flashing a trusted local handyman might be your best bet, but you asked about a roofer or a chimney man, so I would advise the roofer, he'll probably be cheaper than the chimney guy.
Hope that helps out & welcome to the forums! :D
Colin 06-07-2005 05:54 PM
Thanks housedocs. I'm quite sure it's the flashing. I redone the roof about 4 years ago and the flashing at the time was an issue. I have since noticed a slight stream of water that is running down the chimney from under the soffit.
AaronB 06-26-2005 05:39 AM
an experienced ROOFER (not any toothless shingler) should be able to take care of the chimney flashings. I would not trust any old handyman to work on your roof, as he is most likely underinsured and underqualified. Look for a reputable roofing company and expect to pay more than a handyman for their expertise and professionalism.
CarpenterDon 06-28-2005 06:24 AM
Any good carpenter or roofer could fix your roof problem.
A general handyman though I would not enlist for such a project.
AaronB 06-28-2005 07:49 AM
I finally found a carpenter that has the personal strength to admit that he knows jack about roofing. AMEN!
Carpenters should stick to building and leave the waterproofing to the roofers. I have repair countless roofs installed by carpenters.
