Leaking Felt - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-19-2010, 12:31 PM   #16
How long has the synthetic stuff been out ?
$80-100 for a 10sq roll....not sure what felt covers ...2 sq for #30, 4 sq for #15 ?
Old 05-19-2010, 12:37 PM   #17
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
$80-100 for a 10sq roll....not sure what felt covers ...2 sq ?
I've been using it for 7-8 years. Not sure how long it was available before that.
It's more like $130 for a 10 sq roll. 15lb felt is 4sq/roll and 30lb is 2sq/roll.
There is significantly less labor installing synthetic underlayment and the brands I'm familiar with have open times of at least 6 months.
seeyou is offline   Reply With Quote
Old 05-20-2010, 08:38 PM   #18
I'm certainly a Pro, but my customers have to "put up with" a temporary roof covering. It's not that hard to dry in a roof and I did it with felt before the synthetics were available. But there is a difference between "drying in" and "blacking in"\
My thoughts exactly
johnk is offline   Reply With Quote
Old 05-20-2010, 10:34 PM   #19
Tom Struble's Avatar
Rewards Points: 2,002
not really a question of ''putting up'' with temporary roofing is different than ''putting up'' with water in their house
and i have nothing but respect for the pro roofers on here,you guys know this
Tom Struble is offline   Reply With Quote
Old 05-20-2010, 10:55 PM   #20
Commercial Roofing
AaronB's Avatar
It was most likely done wrong. No more, no less. Unless he used a perf 15 or another improper underlayment, then he did it wrong.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-21-2010, 09:01 AM   #21
Doing This Way Too Long
Rewards Points: 532
I'm kinda wondering if it was glass ply and not felt
OldNBroken is offline   Reply With Quote
Old 05-21-2010, 10:29 AM   #22
Rewards Points: 1,534
Originally Posted by seeyou View Post
But I don't think I'd even consider using 20 y/o felt. The OP saved $45 up front, but what did it ultimately cost him?
Did the felt move in the wind causing the staple holes to enlarge?
Let alone did the felt get torn in the wind?
Old 05-21-2010, 04:06 PM   #23
Residential Roofer
Slyfox's Avatar
I was wondering the same thing.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 05-22-2010, 04:53 PM   #24
MJW
Sorry guys, not me. I wasn't saying anyone couldn't paper in a house and be water-tight, just saying I wouldn't take the risk with my customers.
MJW is offline   Reply With Quote
Old 06-14-2013, 12:21 PM   #25
Dave88LX's Avatar
Rewards Points: 566
I'm certainly a Pro, but my customers have to "put up with" a temporary roof covering. It's not that hard to dry in a roof and I did it with felt before the synthetics were available. But there is a difference between "drying in" and "blacking in".
What do these two things mean?
Dave88LX is offline   Reply With Quote
Old 06-14-2013, 02:27 PM   #26
Roofmaster
Rewards Points: 2,210
Dollar to a doughnut that felt was left over from the built up low slope roof on the warehouse and it is perforated felt for use in Built up roofing. The perforations are to allow trapped air out and strike through of the asphalt. It may also be Tar impregnated (Coal Tar) in which case you do not want it anywhere near asphalt products. Did the felt say it was ASTM D-226, type 2, Perforated on the label?
Also, the guys are right. You only remove what you can put back in the same day.
We have voted, and you have been found wanting.
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
Felt for Reinke Alum Shakes SCDome Roofing/Siding 1 09-26-2009 01:53 PM
How do I attach the 15# roofing felt to the subfloor? rncopper Flooring 8 06-23-2008 09:17 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
