Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-10-2011, 10:25 AM   #1
Leaking between gutter and fascia board
I just had my gutters installed about a month ago. Today it is raining and I noticed a dripping between the gutter and the roof edge. I need to call the guy back. What should the guy have installed to prevent this problem?
Jo Wag is offline   Reply With Quote
Old 03-10-2011, 11:04 AM   #2
Would have to see a picture to know the exact reason water was getting behind the gutters. However, installing a metal drip edge over the back of the gutters and under the shingles would solve your problem. You (or your contractor) can get the material at Home Depot, Lowes or any roofing supplier for about $3-$5 per 10' piece. Simple to install.
DUN-RITE ROOFING INC.
THE ROOF DOCTOR OF TULSA
dghazelwood is offline   Reply With Quote
Old 03-10-2011, 04:24 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
If the gutters are low,try an apron type as well.Something is needed between the upper rear gutter and the roof line.Also is it leaking or dripping at a seam(if not seamless)or a corner joint? Junction? Are they draining creating an overflow.
Roofmaster417 is offline   Reply With Quote
Old 03-10-2011, 08:54 PM   #4
Do you have 2x3 or 3x4 downspouts?
handy man88 is offline   Reply With Quote
Gutter installation questions Homerepairguy Roofing 7 03-15-2012 11:22 AM
Water/Ice on fascia leaking into sofit and house da_man Roofing 1 02-07-2011 04:22 PM
fascia board for 6 inch gutter ToroMich Roofing 2 07-31-2010 05:22 AM
Fascia Board - Gutter Install handy man88 Roofing 6 02-22-2010 08:48 PM
12" Fascia Board Maralind Roofing 6 01-26-2009 06:26 PM
