Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-18-2011, 09:12 AM   #1
Leaking balcony
Found my answer.
GeorgiaV is offline   Reply With Quote
Old 04-18-2011, 11:31 AM   #2
Shut in w/o Home
seeyou's Avatar
Leaking balcony
Originally Posted by GeorgiaV View Post
My balcony leaks. I tried to fix it last year. We put 2 layers of tar paper over the plywood that was already there. Then we put another layer of plywood over the top. I only calked the cracks and holes (realize now did this wrong). What is the best way to fix this?
I'm holding back on the smartass comments, but it's gonna be tough on this one.
There is nothing that you did here that even comes close to being a "roof".
You must keep the water out 1st and then think about building a deck on top of it that doesn't damage what you used to keep the water out.
What's your budget for this project?
There are several ways to approach this: There are paint on with mesh coatings, membranes, and metal, going from easiest to difficult.
seeyou is offline   Reply With Quote
Old 04-18-2011, 01:18 PM   #3
Leaking balcony
Not sure what you mean by smartass comment. If you don't want to help don't comment.
thanks anyway.
Old 04-18-2011, 01:43 PM   #4
"Nail-Bender"
Leaking balcony
Hi! GeorgiaV
See if you can post some pictures.
Quite often, over the Internet, it can be difficult to completely understand
what you're talking about.
Regards!
rossfingal
rossfingal is offline   Reply With Quote
Linoleum to cover leaking cement balcony? max987 Building & Construction 11 12-11-2010 09:19 AM
Leaking Flat Roof Balcony briantroy Roofing 5 12-08-2010 11:47 PM
leaking roof couchguy Roofing 1 02-13-2010 05:43 PM
hello , i have a leaking balcony over a room amanda everson General Discussion 3 10-03-2009 10:48 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
