Leaking Around Chimney Of Double Wide - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-03-2011, 01:48 PM   #1
Leaking around chimney of double wide
We installed metal roofing on a double wide a couple yrs. ago. It leaks around the chimney onto the furnace..help
lenni is offline   Reply With Quote
Old 02-03-2011, 01:52 PM   #2
Residential Roofer
Slyfox's Avatar
Can you post a picture?
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 02-22-2011, 04:50 PM   #3
Use wet n dry roof mastic now, in spring use good grade of elastomaric coating
flatroofing is offline   Reply With Quote
Old 02-23-2011, 03:01 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
You must have used some form of caulking to seal it. None of them work. What needs to be done is have the panels in front in place, then the side panels, then a rear panel that the upper ones land on.
All other methods will fail. Some sooner than others.
Cruise my photo albums here, http://www.rooferscoffeeshop.com/pho..._list.asp?u=30 and on my site. (In my sig.) Pay attention to the details in the Metal Details album. Some of the other albums have other relevant details too.
tinner666 is offline   Reply With Quote
Vinyl sided chimney on side of house - rotting OSB rfleege Roofing/Siding 55 11-23-2010 08:23 AM
Bubbling paint from a leaking chimney UpComingBuilder Roofing/Siding 0 04-17-2010 09:04 PM
Any good brick chimney water repellents? quigleybmd Roofing/Siding 3 04-12-2010 06:19 PM
Damp wall by chimney Allanmd General DIY Discussions 9 12-02-2008 11:19 PM
Gonna side my double wide, how do I find the lowest corner. Please Help tnb Building & Construction 4 04-17-2008 07:51 AM
