Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-01-2009, 05:38 PM   #1
Default Leak Issues
During Inspection of home I am to purchase, two roofing issues were noted. No flashing where shingles meet vertical brick wall & no starter strip. Can I install step flashing without removing the shingles & what's the best way to resole the lack of starter strip without removing shingles?
Thanks,
Bill
Bill65 is offline   Reply With Quote
Old 11-02-2009, 10:24 AM   #2
Shingles are going to have to removed in order for it to be done properly. Sorry.
BamBamm5144 is offline   Reply With Quote
Old 11-02-2009, 10:47 AM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Where do you have leaks?
It may be possible to cut & install a starter strip under the current shingles
Is there IW shield under the shingles?
Step flashing could be inserted under the shingles
To do it right the flashing is supposed to be inserted into the grout lines between the bricks & sealed
So might be a PIA
Others have also just sealed the flashing to the brick - but may not be a good long term solution
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
More On This Topic
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Hi I am Adolph Ramirez from Tampa, Florida and on behalf of Expert Village today I will show you how to clean a shower head. So everything is assembled, I went ahead and took the whole thing apart and we cleaned it all out. We got all of the mineral... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. The compressors can have problems with the electrical devices that turn the clutch on. A lot of times you'll hear the clutch kick on when the air conditioning clicks on and off... Read More »
Hi! This is John on behalf of expertvillage.com. In this video clip, I will be showing you how to check for transmission fluid leaks. When checking for transmission fluid leaks, the first place I typically check is the seal, where the transmission fits... Read More »
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 03:26 PM
Persistent Leak - Chimney or Roof? CMoorhead Roofing 10 01-08-2009 07:45 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 08:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 10:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing 4 05-06-2008 03:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
