Leak In "false Chimney" - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-08-2012, 08:12 AM   #1
Leak in "false chimney"
I have two very large brick chimneys which are just framed with 2 X 4s and covered with plywood and then bricked. The gas log fireplaces just vent out the back so the chimneys are just for looks....my problem is that both are leaking from the top! The top is just filled with a thin layer of concrete on top of a plywood cover which is leaking down and into my house. About a year ago I had a roofer apply a layer of some type of thick liquid which dried to a grey hard cover but it has since cracked and is flaking off in large pieces allowing the water to again seep through the concrete top into the fake chimney and into the house. This house is only 3 years old. I am looking for some permanent fix to this problem. Do I need a roofing person or a concrete weatherproofing person? The chimneys are quite large, 41inches by 58 inches outside demensions. Thanks for any ideas or suggestions.
MrBuck is offline   Reply With Quote
Old 01-08-2012, 08:23 AM   #2
Rewards Points: 14,312
Any handi man, roofer, or even a mason should be able to handle this one.
Instead of trying to keep going back and fix this all the time if it mine I would come up with a cap to cover the whole top area instead.
Now that someone has tryed sealing it instead of doing a tuck pointing job it's going to be harder to repair.
Morter on top of plywood was a very bad idea and will continue to crack.
I'm surprized the fake bricks have stayed on.
MrBuck (01-08-2012)
Old 01-08-2012, 08:38 AM   #3
Rewards Points: 2,240
What "joecaption" says.
Some type of cap -
galvanized - copper.
Not knowing the exact, construction -
Concrete cap on 3/4 inch plywood, may not be the way to go.
You could post some pictures.
rossfingal
rossfingal is offline   Reply With Quote
Old 01-08-2012, 08:40 AM   #4
Thanks Joe. One point of clarification...they are not fake bricks. The bricks are real..the chimney is the fake part since it has no flu.
Old 01-08-2012, 08:49 AM   #5
Are the thin bricks just attached to plywood?
Plywood expands and contracts, not a good thing when it comes to morter.
Old 01-08-2012, 09:10 AM   #6
Yes, the bricks are just attached to the plywood with the metal attaching brackets tied into the mortar joints in the brick. That is a pretty standard way of doing "brick facing" in my area.
Old 01-08-2012, 10:01 AM   #7
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
That's brick veneer on a "chase". You need a metal chase cover.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
rossfingal (01-08-2012)
Tags
chimney leak , fake chimney leak , leak , roof
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
leak leak leak dongdong1 Building & Construction 4 01-11-2011 09:21 PM
Freon Leak captainron19 HVAC 3 04-16-2010 04:30 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
