Leak Due To Broken Sheathing. Repair Advice? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-15-2013, 02:48 AM   #16
747
registered
747's Avatar
Rewards Points: 534
Your roof has about 5 years left in it. The good news is. Simple roof or a reroof. You have some serious routing plywood in the one section. Its been leaking for a while. Follow jagan and old n broken advice. Start saving for a new roof. Your looking about about 7k. Your roof looks to be around 16 square give or take. 250 a square few add ons. You get the pic on price.
747 is offline   Reply With Quote
Old 06-15-2013, 06:16 PM   #17
Dave88LX's Avatar
Rewards Points: 564
Originally Posted by OldNBroken View Post
Pitch is fine. That is a 235 hud home I'd say mid 70's.
Yessir, 1979. What is a "235 HUD" home?
I thought that was that aluminum crap. That stuff is horrible. If it's in your budget I'd spring for some airvent II and replace that thing. It's a waste of money trying to reseal it. Well re-seal would not be the proper term since it was never sealed originally. Use the time and material you will spend trying to make that nice and put a real ridge vent on that will actually work and actually keep the weather out.
My ridge is 38' long, about how much money in materials are we talking?
Originally Posted by jagans View Post
Yup Airvent II and run it out to the end, but end the cut about a foot in. Like this:
If I'm following, the actual gap in the roof will end ~1' in from the ends, but the Airvent II runs all the way to the end?
I hate the look when people cheap out and end it at the wall
Not sure what that means...
Is that $7K materials, or $7K material & labor?
The roof isn't as bad as those two pictures lead it on to believe, I can see why it'd appear that way. There are only the two isolated spots near the ridge. The rest of it is fine (from underneath).
I'm putting the house up for rent here in a couple months. I hope I can get a decent amount of time out of the roof.
Everything else looks fine like this:
Dave88LX is offline   Reply With Quote
Old 06-15-2013, 06:23 PM   #18
Dave88LX's Avatar
Rewards Points: 564
Which one am I looking at here?
http://www.lowes.com/Search=shingle+...=shingle+vent#!
Old 06-15-2013, 06:29 PM   #19
Rewards Points: 13,300
Wrong vent for that style roof.
The right vent would have no exposted nails.
http://roofing.owenscorning.com/home...idgevents.aspx
Old 06-15-2013, 09:18 PM   #20
Roofmaster
Rewards Points: 2,172
Your follow up pictures are good. Your leaks originated at the deficient ridge cap. I think If you do what we recommended you will be fine. Your current ridge cap is grabage as ONB stated. Your shingles are basic three tabs. I think you can probably get a good 8-10 years out of those shingles, even though they were not installed very well re adjusting the exposure at the ridge. Black Mold on shingles in MD is pretty common
Old 06-16-2013, 01:12 AM   #21
Dave88LX's Avatar
Rewards Points: 564
So the Air Vent ShingleVent II is wrong for my roof type?
The Owens Corning has three different styles:
  • VentSureŽ 4-Foot Strip Heat & Moisture Ridge Vents with Weather PROtectorŽ Moisture Barrier
  • VentSureŽ Rigid Roll Ridge Vents with Weather PROtectorŽ Moisture Barrier
Old 06-16-2013, 10:13 AM   #22
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
Shingle Vent II is fine for your roof.
It is one of the better ridge vents out there.
Old 06-16-2013, 11:10 AM   #23
Doing This Way Too Long
Rewards Points: 532
ShingleVent II is what I would put on it. Vent plus new ridgecap you are looking at about $5/ft plus a few hours of work. Since you are already going to have it opened up you are half way there labor-wise.
OldNBroken is offline   Reply With Quote
Old 06-16-2013, 03:14 PM   #24
Registered User
Rewards Points: 5,266
Ventsure did not fair well in tests, pp.8; http://www.google.com/url?sa=t&rct=j...5X2VkfoWu6CAwQ
Use 8d (2-1/2") nails, not screws to satisfy your H.O.Insurance carrier, if ever a claim; #30--- http://publicecodes.cyberregs.com/ic...002_par005.htm
Yours is lacking the inner filter; "What is the purpose of the filter in the ridge vent?
Air Vent's internal weather filter is designed to be a secondary layer of defense against weather, dust and insect infiltration in the attic." From; http://www.airvent.com/professional/...shooting.shtml
Gary
Old 06-16-2013, 03:31 PM   #25
Dave88LX's Avatar
Rewards Points: 564
Got it. Why did joecaption say AirVent II was wrong?
Which one specifically will I need to get at Lowe's?
Gary -- Thank you for the regs! Always interesting to read your posts.
Old 06-16-2013, 08:41 PM   #26
Rewards Points: 532
I don't know if the big-box stores carry shinglevent.
Last edited by Gary in WA; 06-16-2013 at 10:12 PM. Reason: removed content per forum rules.
Old 06-16-2013, 10:17 PM   #27
Registered User
Need to wait and ask Joe on that...
Gary
Old 06-17-2013, 12:08 AM   #28
Rewards Points: 532
Awww c'mon Gary. sheesh
Old 06-17-2013, 09:01 AM   #29
Dave88LX's Avatar
Rewards Points: 564
Their site says they do:
Lowe's
Ace
True Value
84 Lumber
I'll need to pop in and see.
Old 06-19-2013, 05:18 PM   #30
Registered User
I don't have ESP, you can answer for him if you know his reasoning.... maybe looking at the link Joe thought it was something different than we are showing, I don't know... Gary
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 09:47 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 08:46 PM
Outdoor faucet leak repair pistolkell General DIY Discussions 13 07-25-2012 07:23 AM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 09:38 AM
