Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-12-2012, 04:41 PM   #1
Leak in barrel tile roof
My 13 year old barrel tile roof has developed a leak. I found the leak in the attic and the arrow in the picture shows the approximate position of the leak. I also attached a picture of the tile.
How is the best way to repair this leak. I think removing carefully removing several tiles around the suspected area of the leak and replacing the tar paper is the way to do this but am not sure. Any help and tips would be appreciated.
Thanks in advance,
Timn
timjet is offline   Reply With Quote
Old 09-12-2012, 07:27 PM   #2
Carefully remove several tiles just after it rained and it leaked. Look for wet areas on the tar paper above the spot you marked with the arrow.
The actual leak (probably a cracked tile) could be some distance from where you marked.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
Windows on Wash (09-13-2012)
Old 09-12-2012, 10:59 PM   #3
Thanks AllanJ. How do you recommend fixing the leak once it's found?
Fix or Replace Roof Tile? greentrees Roofing 16 04-30-2012 06:50 PM
Proper transition between shed roof and shingled roof? aribert Roofing 9 04-12-2012 04:17 PM
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
Roof leak around my chimney - update GlennAble Roofing 3 11-05-2009 07:24 PM
Tile roof questions/repairs help please xoroniox Roofing 3 12-17-2006 03:02 PM
