-   -   Leak in barrel tile roof (http://www.diychatroom.com/f9/leak-barrel-tile-roof-156625/)
timjet 09-12-2012 03:41 PM
2 Attachment(s)
My 13 year old barrel tile roof has developed a leak. I found the leak in the attic and the arrow in the picture shows the approximate position of the leak. I also attached a picture of the tile.
How is the best way to repair this leak. I think removing carefully removing several tiles around the suspected area of the leak and replacing the tar paper is the way to do this but am not sure. Any help and tips would be appreciated.
Thanks in advance,
Timn
AllanJ 09-12-2012 06:27 PM
Carefully remove several tiles just after it rained and it leaked. Look for wet areas on the tar paper above the spot you marked with the arrow.
The actual leak (probably a cracked tile) could be some distance from where you marked.
timjet 09-12-2012 09:59 PM
Thanks AllanJ. How do you recommend fixing the leak once it's found?
