Lead Boot Installation - Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-20-2013, 07:47 PM   #16
Roofmaster
Rewards Points: 2,210
Originally Posted by tinner666 View Post
Perfect example of a leaker. Sorry to hear you were treated that way.
Half of that collar belonged on top of the roof. No black stuff needed either. http://www.albertsroofing.com/Power%...stallation.htm
Exactly. The ribs are normal. This looks like an old 4 lb lead pipe jack that was re-purposed on your roof. 3 Lb is actually more malleable and easier to work with. The lead should be turned down into the pipe at least an inch. I actually prefer a separate lead collar that slides into the pipe and counters the lead pipe jack.
There should be no roof mastic on top of the pipe. Very poor work.
Insulating kneewalls vs roof in 1929 house BadHouse Insulation 6 01-27-2013 02:58 PM
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 09:44 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
