Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-09-2005, 12:01 PM   #1
Lathe metal roofing?
We're ready to recover our roof at our church. We're getting different opinion concerning whether to lathe under the 29 gauge metal roofing we want to install. One wants to strip the shingle roofing and refelt and then install the metal roofing. Another wants to strip or lathe with 1" X 4" 's and then screw down the metal roofing. We'd appreciate any advice on this project. Thanks
Stan ETenn is offline   Reply With Quote
Old 02-09-2005, 10:28 PM   #2
29 gauge is too light. I never see anything less than 26 guage or 24 gauge over supports. I'm sure that if metal this thin is installed over 1x4's it will bend and deform. The hinner the matal, the beeter the deck surface has to be. The metal roofing mfr's have tables listing the approved spans for supports for all of the guages & profiles they offer. AEP-Span, MBCI, Berridge, IMSA,& Metal Sales are some companies. Type "metal roofing" into Google.
Jim
jmorgan is offline   Reply With Quote
Old 02-10-2005, 02:40 PM   #3
Contractor
I agree with jm, 29 ga is too light for almost anything and oilcans even on solid decking.
Teetorbilt is offline   Reply With Quote
Old 02-10-2005, 02:58 PM   #4
Whatever the standard gauge steel roofing on the latest houses and churches is what we will be using. It's usually spanned 18" to 24". Thanks
Old 02-11-2005, 01:03 AM   #5
What type of metal roof are you going to installing, does it have a name, like pro panel or rugud rib? Is it a standing seam type or are the panels 3ft. wide, with small ribs spaced aprox. 9" apart. It matters...
johnboy52 is offline   Reply With Quote
Old 02-12-2005, 07:52 PM   #6
It's the 3ft. panels. They have the 25 yr. warrenty. With the steep fall on our roof I think they will last much longer. I think it's important to be sure they are installed right.
Old 02-14-2005, 12:35 PM   #7
that type of metal roof is usally sold in 29 gauge, you can get it in 26 gauge if you feel it's worth it. You must tear off the roof on now, even though the sales people say you don't have to. You must have solid decking. I've installed plenty of these roofs mostly in the mountains, on cabins, and summer homes. Their very popular, and come in many colors. Ther are some tricks to know installing this roof, like you must take every nail out that will not lay flat, after you tear off the old roof, as this roof will transfer any bump right through, and you will see it, especialy on a steep pitch. That means no cap nails used on the paper either, you can only use small stapels to install the paper, (hammer tacks), or you will see every nail! The screw pattern is every 9" across and every row is every 2ft. up-follow me? Look at where the screws are to be installed, There is a sheet showing screw placement. The paper you use had better be 30lb type 2 (heavy)
Old 02-17-2005, 05:07 PM   #8
I can help you more on the installation of this type of roof, if you wish e-mail me and use your e-mail so I can get back to you. If this roof is installed correctly on a step pitch it will work just fine.
Old 02-18-2005, 03:51 PM   #9
Commercial Roofing
AaronB's Avatar
I hope it isnt the trapezoid panel like on metal buildings.....that stuff is horrible looking.
www.roseroofing.net OUR SYSTEMS CAN PAY YOU BACK!
SEAMLESS Polyurea Roofing for Metal, Roof Repair and Sealing, Roof Leak Repair, SEAMLESS Commercial Spray Foam Insulation, SEAMLESS Commercial Roofing, SPF, Industrial Insulation and Coatings, Energy Efficient Roofing, Roof Maintenance.
AaronB is offline   Reply With Quote
More On This Topic
When it comes to a tornado it doesn't matter what the intensity of it is if your house is not properly built to withstand it. If your house is not wind-proofed it can suffer a lot of damage. Follow these steps to prepare for a tornado and prevent... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. All panels are fastened through the front lip with a minimum of four fasteners per panel. Building codes or special conditions may require more, please... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will be showing you how to install our side trim. Our side trim is the side piece that goes all the way up the left side and the right side of our wall. Once it's up it is going to make a... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be installing the cleats. To install the cleats I will be using wood glue, a pin nailer with 1/4" pin nails, and a tape measure, and writing utensil. I have cut my cleat board a little... Read More »
metal roofing nomoney Roofing 27 01-12-2009 10:29 PM
Metal Roofing for Experienced Beginners rezroofers Roofing 3 06-21-2007 12:42 AM
Cricket Construction on Metal Roofing? Lion Gordon Roofing 1 07-20-2005 10:59 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
