-   -   Lathe metal roofing? (http://www.diychatroom.com/f9/lathe-metal-roofing-336/)
Stan ETenn 02-09-2005 11:01 AM
We're ready to recover our roof at our church. We're getting different opinion concerning whether to lathe under the 29 gauge metal roofing we want to install. One wants to strip the shingle roofing and refelt and then install the metal roofing. Another wants to strip or lathe with 1" X 4" 's and then screw down the metal roofing. We'd appreciate any advice on this project. Thanks
jmorgan 02-09-2005 09:28 PM
29 gauge is too light. I never see anything less than 26 guage or 24 gauge over supports. I'm sure that if metal this thin is installed over 1x4's it will bend and deform. The hinner the matal, the beeter the deck surface has to be. The metal roofing mfr's have tables listing the approved spans for supports for all of the guages & profiles they offer. AEP-Span, MBCI, Berridge, IMSA,& Metal Sales are some companies. Type "metal roofing" into Google.
Jim
Teetorbilt 02-10-2005 01:40 PM
I agree with jm, 29 ga is too light for almost anything and oilcans even on solid decking.
Stan ETenn 02-10-2005 01:58 PM
Whatever the standard gauge steel roofing on the latest houses and churches is what we will be using. It's usually spanned 18" to 24". Thanks
johnboy52 02-11-2005 12:03 AM
Type of roof
What type of metal roof are you going to installing, does it have a name, like pro panel or rugud rib? Is it a standing seam type or are the panels 3ft. wide, with small ribs spaced aprox. 9" apart. It matters...
Stan ETenn 02-12-2005 06:52 PM
It's the 3ft. panels. They have the 25 yr. warrenty. With the steep fall on our roof I think they will last much longer. I think it's important to be sure they are installed right.
johnboy52 02-14-2005 11:35 AM
that type of metal roof is usally sold in 29 gauge, you can get it in 26 gauge if you feel it's worth it. You must tear off the roof on now, even though the sales people say you don't have to. You must have solid decking. I've installed plenty of these roofs mostly in the mountains, on cabins, and summer homes. Their very popular, and come in many colors. Ther are some tricks to know installing this roof, like you must take every nail out that will not lay flat, after you tear off the old roof, as this roof will transfer any bump right through, and you will see it, especialy on a steep pitch. That means no cap nails used on the paper either, you can only use small stapels to install the paper, (hammer tacks), or you will see every nail! The screw pattern is every 9" across and every row is every 2ft. up-follow me? Look at where the screws are to be installed, There is a sheet showing screw placement. The paper you use had better be 30lb type 2 (heavy)
johnboy52 02-17-2005 04:07 PM
I can help you more on the installation of this type of roof, if you wish e-mail me and use your e-mail so I can get back to you. If this roof is installed correctly on a step pitch it will work just fine.
AaronB 02-18-2005 02:51 PM
I hope it isnt the trapezoid panel like on metal buildings.....that stuff is horrible looking.
jagans 06-17-2013 03:48 PM
Why would you attempt to do this yourself? You need professional help with the design of your roof. I don't know where your differing opinions are coming from, but I hope its not contractors. You have given us no data on your roof, whatsoever, so nobody here can guide you on what to do.
You cannot just slap a new roof over what you have without knowing the design load of the current structure, but generally speaking you do not want to roof over an existing roof.
Dont be fooled by warranties. There is only one metal roofing manufacturer that issues a 20 year Water-Tight warranty that I know of. There are other metal roof suppliers that tout long term warranties, and they are limited to the finish, or to leaks Through the Panel, not around it.
Metal roofs have to be specified, designed, and installed properly or they will leak from day one till you tear them off. If all of the above is done right, they will last 50+ years with minimal maintenance.
You need help. I can tell by your post.
jagans 06-17-2013 03:57 PM
The trapezoidal shape broken into the panels on Trapezoidal Structural Standing seam roofs is functional. It is there so the roof can support the live loads it will be expected to carry. The panels generally span 5 feet and do not require a structural deck below. They are used on large pre-engineered buildings where cost per sq foot of space is of paramount importance. They are not meant to be aesthetically pleasing like an architectural standing seam roof. Besides, I bet the female panels look pretty good to the male ones. :laughing:
AndyWRS 06-17-2013 05:13 PM
1. The OP never told us the name of the product so we are all still guessing as to what spec to follow.
2. Sounds like something other than SS, possibly a stone coated panel given the size the OP provided.
3. Its an eight year old thread :huh: and we still dont know what the roof type is.
jagans 06-18-2013 09:18 AM
I have asked the guys that run this sight time and again why old posts come up bold, making us think they are new ones, but they haven't fixed it yet. They really dont do anything the regulars ask them to, like going back to the old face, which was way more user friendly. Its like MS Office, the best version was 5.1 what are we on now 14? I guess the programers have to justify their income.
TheEplumber 06-18-2013 09:34 AM
199 Attachment(s)
Originally Posted by jagans (Post 1203191)
I have asked the guys that run this sight time and again why old posts come up bold, making us think they are new ones, but they haven't fixed it yet.....
This is news to me- never seen this issue before. I will forward this issue up the ladder.
Each post is time stamped too. Maybe look at that stamp before replying?
jagans 06-18-2013 11:09 AM
You mean old posts do not come up bold on your computer for no apparent reason?
