Laminiated Roof Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-05-2010, 02:29 PM   #1
Are special shingles required for the roof cap? For instance, if the field shingles are rated for 110 mph, do the ridge cap shingles need a higher rating in order for the entire roof to qualify as 110? Is it okay to use the field shingles on the ridge cap?
billsweg is offline   Reply With Quote
Old 06-05-2010, 02:51 PM   #2
Residential Roofer
Slyfox's Avatar
Custom ridge caps "hip & ridge" or 3-tabs 'if your using a color that can be matched', but not the field shingles.
You shouldn't use the field shingles for starter strips either unless you cut the lower 'exposed portion' off and just use the nailer portion as your starter.
The make starter strips or you can use 3-tabs for that as well.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 09:46 PM
Epoxy roof sealant over shingles? P550 Roofing/Siding 15 04-11-2009 11:00 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 11:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 06:39 PM
