Lack Of Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-31-2010, 04:31 PM   #1
Solutions (handyman)
Rewards Points: 364
Lack of ventilation
Our daughter and son-in-law have a house that is about 40 years old. The roof has good vents plus a whirley bird vent, however, the area inside the soffits (between the walls and the roof) have been boarded up. I think that this was an oversight when they built the place. Anyway, the soffits are vented but we don't think the air circulation can enter the attic. Any suggestions for creating proper air flow? My son in law tried to access the boarded up area from the attic but it is too tight to get to.
Mark Harvey is offline   Reply With Quote
Old 10-31-2010, 06:17 PM   #2
If I understand your predicement correctly,Cutting wide slots(as wide as possible) as close to the top of the boards as possible should do the trick.
johnk is offline   Reply With Quote
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Intake ventilation vs exhaust ventilation gwald Roofing/Siding 1 06-05-2010 04:55 PM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 11:19 AM
Proper Balanced Ventilation? echase Roofing/Siding 8 04-21-2010 04:44 PM
Light, Ventilation, and Heating code requirements sarbear HVAC 12 11-30-2009 11:10 AM
