-   -   KickOut Flashing (http://www.diychatroom.com/f9/kickout-flashing-181912/)
jpm6621 06-16-2013 12:12 AM
KickOut Flashing
1 Attachment(s)
Is this kickout flashing installed properly? It seams like it extends too far pass the eave for a gutter to be installed. And whoever installed the siding used some kind of rubber caulking where the siding was cut to fit around the fascia, I was wondering if anyone knows what type of caulking this is or what caulking is best for vinyl siding in this situation. Polyurethane? Elastomeric? Synthetic Rubber? There is just 100% silicone around the kickout flashing/siding right now.
jpm6621 06-16-2013 12:18 AM
1 Attachment(s)
This is the other side kickout flashing, it's just regular step flashing made into a kickout. There is ice and water guard behind the siding and 1/2" foam. Do i even need the kickout flashing here? Can someone explain how to rotate my pictures?
Windows on Wash 06-16-2013 10:11 AM
It is tough to tell if it is correct without looking under the shingle or behind the siding but the general appearance tells me that it is something that this installer hasn't done much of before.
I would therefore be wary of the correctness.
The siding is cut way to close to the roof deck so, if this was done by the same person, we have problems already.
Fix'n it 06-16-2013 10:19 AM
how i do it : open the pic in your picture viewer. rotate it. then advance to the next pic, then back to the original pic.
Fix'n it 06-16-2013 10:23 AM
rotated .......
joecaption 06-16-2013 10:32 AM
What in the world did they use for a facia? Looks like a funnel to get all the water to go behind the wall and rot it out.
No drip cap, shingles left to short, J moulding to close to roof
jpm6621 06-16-2013 11:55 AM
It looks like crap i'm going to take it out, the wall never had water damage without kickout's. Basically theres step flashing running all the way down then the kickout being the last piece. Where should dripcap be installed? There is dripedge on the eave with the shingles flush with it. The fascia is aluminum made in a break to form around the old fascia board. From the eave, the fascia runs back in towards the house. So how do you run j channel around that inside corner which is not straight, if thats what needs to be there? How far should that j channel thats on the roof extend past the edge of the roof. Basically whats the best way to fix this.
jpm6621 06-16-2013 02:32 PM
1 Attachment(s)
Another View.
tinner666 06-19-2013 07:05 AM
It's incorrect. The siding is supposed to have been cut horizonally, not verticaly, inside,under, the 'ship-lap' where the current top edge of the flashing stops. Then, the cut is invisible. The flashing would still come out as far as it currently does.
The top edge of the flashing would also be hidden, even if it meant making it a tad taller.
