Just When You Thought It Was Over... Leaking Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-23-2011, 01:19 PM   #1
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Just when you thought it was over... Leaking roof
So, I have posts all over the place about this stupid attic.
Last night, after getting growled at by the resident squirrel, I started getting dripped on.
The current roof was installed over the original wood and there are pretty wide gaps between some of the boards. The brilliant individuals who did the roof put tar paper down, then the shingles, and many of the nails don't go into anything at all. How can you not notice that???
So anyway, there are lots of nails that are dripping.
I can't get up on the roof and do anything about it at the moment. Is there anything I can do from the underside? If I wait until they are dry, will caulk around the nails do anything to help? I'm only thinking that if I can stop the flow then maybe the water will go down the roof instead of through it?
This has been going on for years so it's not any more of an emergency now than it was 24 hours ago when I didn't know about it. However, I'd like to do something about it as a stop-gap if possible.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 11-23-2011, 02:36 PM   #2
Rewards Points: 1,772
Nope, water flows downhill, caulking from below won't help.
Rig up some plastic sheeting (like an upside down tent) from the rafters to funnel the water dripping into the middle of the sheet into a bucket. At least you will have contained the leak until the roof can be repaired in warmer weather.
bob22 is online now   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Gymschu (11-23-2011)
Old 11-23-2011, 02:47 PM   #3
Gymschu's Avatar
Rewards Points: 1,034
Bob is right, there's no magic cure-all from the inside. If you caulk the nails the water will simply push the caulk right off. If you can contact a handyman or a roofer in your area, perhaps they can tarp the troubled areas of your roof for now and then make the needed repairs in the spring.
Gymschu is online now   Reply With Quote
Old 11-23-2011, 05:44 PM   #4
The nails missing wood, in it self, would not make a roof leak. You have more problems.
framingrailman is offline   Reply With Quote
The Following 2 Users Say Thank You to framingrailman For This Useful Post:
MJW (11-23-2011), Tom Struble (11-23-2011)
Old 11-23-2011, 06:20 PM   #5
mnp13's Avatar
Rewards Points: 512
The water is running down the nails and dripping, but I found no drips off of boards or wet boards. I'm not saying there are not other problems though!!
Michelle
Old 11-23-2011, 06:48 PM   #6
MJW
Ventilation and/or insulation problems......?????
MJW is offline   Reply With Quote
Old 11-23-2011, 07:01 PM   #7
sounds like they should have resheeted the old roof deck instead of going over bad shiplap
as far as nails in between the boards means they probaly blew thru the shingles is why it is leaking. sounds like scab roofers and untill you have your roof replaced then resheet it you will always have problems
r00ferguy is offline   Reply With Quote
Old 11-24-2011, 09:59 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
+1
Are you sure the roof is leaking?
The nails will be little cold spots in the roof assembly and if you have dew-point temps and high humidity, the nails will form condensation and look like they are leaking.
The Following User Says Thank You to Windows on Wash For This Useful Post:
framingrailman (11-24-2011)
Old 11-24-2011, 11:30 AM   #9
mnp13's Avatar
Rewards Points: 512
We soaked two towels to "wringing out wet."
They are active drips, not condensation.
My point with the boards was that the nails that didn't go into a board appear to have damaged the shingles and underlayment, and those are the ones that are leaking.
Michelle
Old 11-24-2011, 12:09 PM   #10
If they used an air nailer, that would absolutely be true.
They would blow out the back of the shingle and break the seal healing strip around the nail rendering the shingle ineffective.
Sorry to hear about that.
Old 11-25-2011, 07:08 AM   #11
Rewards Points: 83
This is why we ALWAYS re-sheet over shiplap.
bcdemon is offline   Reply With Quote
The Following User Says Thank You to bcdemon For This Useful Post:
MJW (11-25-2011)
Old 11-25-2011, 10:39 AM   #12
mnp13's Avatar
Rewards Points: 512
Yeah... it's not shiplap. The attic "ceiling" is made up of plain 1x boards that are nailed to the joists. Many are up to 18 inches wide, though the occasional board is 6 inches or so. Most of the boards are very close together, but there are also gaps of up to an inch in places.
It looks like they did a tear off, then just layed down new tar paper and put shingles over it.
Michelle
Old 11-25-2011, 05:19 PM   #13
MJW
Then they are rough sawed boards. No warranty when shingles are put on this roof without resheathing.
I still think it's a condensation issue though. Anything else updated in the home lately?
Old 11-25-2011, 05:55 PM   #14
mnp13's Avatar
Rewards Points: 512
Yes. The original rough boards to the house. I have not been on the roof. So perhaps there is OSB on top of the layer of tar paper that I can see from the attic, but I doubt it.
Well, you're welcome to your opinion, and you're welcome to come over the next time it's raining. ;-)
Seriously though, no, it is not condensation. There have not been any major changes in the house lately, and this only happened when it was raining, not when it was simply cold. Our attic is only marginally warmer than the outside anyway. We only heat the upstairs to 55, we don't use the upstairs bathroom for showers and the downstairs bathroom isn't vented (and neither is the upstairs actually)
Michelle
Old 11-25-2011, 09:04 PM   #15
MJW
It sounds like you are rather confident that it is actually leaking. You should definitely get the roof re-done with new sheathing and new shingles.
There is no telling that you could get by with just a simple patch for the time being. If it leaks that bad with just rain, you will have plenty of problems this winter.
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Roof Leaking - Do I Need to Replace Drywall? dombrorj General DIY Discussions 5 06-21-2010 05:10 PM
1/12 sloped roof leaking w/ asphalt shingles, replacement ideas? Tuffguy610 Roofing/Siding 3 03-17-2010 05:59 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Roof leaking where it intersects wall.. mellody28 Roofing/Siding 6 11-06-2005 09:26 PM
