Just Another Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-13-2012, 02:23 PM   #1
Just another leak
On very windy, rainy days my steel pipe chimney will leak onto the wood stove. From the picture, it leaks right where the pipe first bends. There will be water on the outside of the pipe. The water on the stove will be very rusty.
I've had two professional roofers look at it. One had me move the "flange" down. The other had me put some tar caulking around it and put duct tape over some vents under the flange.
It still leaks!
NotARoofer is offline   Reply With Quote
Old 11-13-2012, 02:28 PM   #2
Rewards Points: 13,256
Tape on the low side of the roof should have been under the flange not on top of it.
I'd be worryed about all those holes in the roof where those brackets are screwed to the roof.
What's up with the seailing around the gray pipe in the back ground?
Looks like there's no roof jack at the bottom and there's some sort of ring sitting way up off the roof.
Old 11-15-2012, 09:26 AM   #3
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
THose angle brackets really should have a pitch pan on each.
"Tar" caulking on an EPDM roof? You just caused major chemical damage to the epdm membrane. A "professional" roofer suggested caulk as a long term solution? A "professional" roofer suggester tar on EPDM? A "professional" roofer suggested duct tape? These guys are Not professionals, IMO.
Slide up the rain collar, field flash the entire cone base flashing, terminate with a hose clamp on the pipe. Slide the collar back down, seal the collar with polyurethane sealant, such as Solar Seal or equivalent.
Really I don't like that cone base flashing. Something like http://www.genflex.com/uploadedFiles...nfo/E-7.06.pdf or http://www.versico.com/documents/reslib/VGC-8.5.pdf is the proper flashing technique. In some situations we will also install a pitch pan like: http://www.versico.com/documents/reslib/VGC-16.2.pdf
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 11-15-2012, 09:30 AM   #4
Grumpy's Avatar
The rusty old rain collar would be acceptable, assuming there is a proper base flashing which really is a base angle.
-Grumpy
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 09:47 PM
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 11:15 AM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 08:26 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
