Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 05-28-2010, 01:02 AM   #1
joining two sloped roofs
Goodday
I'm thinking of adding a room to my balcony , as per attched drawing .
But I'm having a problem with the design of the join , and making this waterproof. Has anyone seen a design which i could use ?
Rob
robhare is offline   Reply With Quote
Old 05-28-2010, 01:24 AM   #2
Doing This Way Too Long
Can't do it the way you have it drawn. Only two ways you can do that is bring that out as a third hip, just like the two big ones. Then you have to cricket both sides between the existing hips and the new one. Or do a shed roof tying into the two hips on the sides and sloping up and tying into the main roof on the back. Shed roof is your best option I think.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
robhare (05-29-2010)
Old 05-29-2010, 03:06 AM   #3
Thanks for your help , I was thinking of keeping the style similar to the rest of the house.
Would the following work , where the join's are all at a slight down angle .
What do you think.
Regards
Rob
Old 05-29-2010, 07:22 PM   #4
Residential Roofer
Slyfox's Avatar
What do you think.
Regards
Rob
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 05-29-2010, 09:11 PM   #5
It was a dark and stormy
Yoyizit's Avatar
Rob
Can't you just flash the joints and have these valleys slightly pitched downward toward the edge of the roof, say 1" per 10', like you said in #3?
Old 05-30-2010, 03:56 AM   #6
Thanks Sly, I was too tired to do that. Don't know if the hips are going to cause issues with it, always been gables when I've done them.
And, no, I would not do anything less than a 2.5 or 3/12. Anything less and you will have standing water and major problems in that long a run.
Old 05-30-2010, 07:16 AM   #7
Residential Roofer
Slyfox's Avatar
The hips will for sure be an high risk area the way they run 'die-out' into the valley, but if the roofer weaves not only the first four or five courses of shingles but also weaves the first same number of caps in with those weaved shingles the detail will work.
I have done several of them, those really good 'creative' minded architects, they are always finding stuff like this to challenge framers & roofers.
Old 05-30-2010, 12:48 PM   #8
"What do ya mean you can't build it? I drew it right here on this paper!"
Those ones?
I like doing full 3-ply flintlastic SA on the crickets.
Old 05-30-2010, 12:57 PM   #9
Yoyizit's Avatar
This guy drew a lot of things that can't be built
http://veritasdomain.files.wordpress...all-medium.jpg
Old 05-30-2010, 01:45 PM   #10
I think I've worked with that architect a few times.
Leveling a sloped concrete pad for tile giveitatry Flooring 6 04-25-2010 10:36 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
Hip roofs and hurricanes cittyguy Roofing/Siding 3 05-23-2009 08:38 PM
Connecting two roofs TazinCR Roofing/Siding 1 07-23-2008 08:37 PM
Connecting two roofs TazinCR Building & Construction 2 07-23-2008 10:19 AM
