Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-13-2011, 11:10 AM   #1
joining metal to shingles
I will be installing a very flat metal patio roof(small pitch) .it has to connect to the asphault roof of home that is steep.What technique is used at the joining area to transition so no leaks will arise?
hidden 1 is offline   Reply With Quote
Old 10-13-2011, 04:09 PM   #2
Pro Slate Roofer
tinner666's Avatar
Remove singles for 2' or so along the transition. Go up the transition with the metal about 18". Flatten the seams and reshingle.
When using some steel standing seam panels, you can 'box-fold' the panel 'flats' like making paper airplanes, and install terminastion flashing that extends 12" up the steep slope, under the shingles, and 8" out over the steel panels. Put pop-rivets through the term flasing into the tops of the panel seams.
Frank
tinner666 is offline   Reply With Quote
Old 10-15-2011, 10:42 AM   #3
can i use a technique that will fold a piece of rolled flashing around fireplace and at lower part of chimney where it meets the metal roofing and trim the lower edges to fit into the grooves of roof then seal it?
like this fireplace
l l
l l
_ _ _ _ _ _ _ _ _ _ _ _ _
l l--------flashing------------ l l
l __ __ __ l
----l--/ \------/ \-------/ \-l-------- l
l l
l metal roofing l
l l
Old 10-15-2011, 10:45 AM   #4
pic shifted
-but you got the idea
the flashing is at the lowest point of fireplace and curves are cut to fit where metal roofing is and it goes over roofing and sealed
Old 10-15-2011, 10:58 AM   #5
http://youtu.be/3CL5in9AJoA
Leed silver home constructing -utube -shows it in detail
Replacing chimney flashing after new shingles tmiles2246 Roofing 18 04-18-2011 02:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing 1 09-18-2010 07:29 PM
Metal Roof Estimate supton Off Topic 5 04-17-2010 04:08 PM
How to drill through metal in headers Docfxit General Discussion 5 07-05-2009 11:31 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
