-   -   joining metal to shingles (http://www.diychatroom.com/f9/joining-metal-shingles-120002/)
hidden 1 10-13-2011 11:10 AM
I will be installing a very flat metal patio roof(small pitch) .it has to connect to the asphault roof of home that is steep.What technique is used at the joining area to transition so no leaks will arise?
tinner666 10-13-2011 04:09 PM
Remove singles for 2' or so along the transition. Go up the transition with the metal about 18". Flatten the seams and reshingle.
When using some steel standing seam panels, you can 'box-fold' the panel 'flats' like making paper airplanes, and install terminastion flashing that extends 12" up the steep slope, under the shingles, and 8" out over the steel panels. Put pop-rivets through the term flasing into the tops of the panel seams.
hidden 1 10-15-2011 10:42 AM
cut in pic
can i use a technique that will fold a piece of rolled flashing around fireplace and at lower part of chimney where it meets the metal roofing and trim the lower edges to fit into the grooves of roof then seal it?
like this fireplace
l l
l l
_ _ _ _ _ _ _ _ _ _ _ _ _
l l--------flashing------------ l l
l __ __ __ l
----l--/ \------/ \-------/ \-l-------- l
l l
l metal roofing l
l l
hidden 1 10-15-2011 10:45 AM
info
pic shifted
-but you got the idea
the flashing is at the lowest point of fireplace and curves are cut to fit where metal roofing is and it goes over roofing and sealed
hidden 1 10-15-2011 10:58 AM
link
http://youtu.be/3CL5in9AJoA
Leed silver home constructing -utube -shows it in detail
