Joining Metal Roof To Asphalt - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-06-2013, 09:25 AM   #1
Rewards Points: 93
Joining Metal Roof to Asphalt
Hi All,
Purchased an old farm home with 3 foot wide roll down asphalt on the shallow pitch porch roof. The main pitch is 9/12. I have shingled many asphalt roofs but the metal thing is new to me.
The little lady would like to have a red metal roof. I'd like to do sections at a time as the 3 tabs on the main pitch are in good shape for now.
Can anyone explain if this can be done (starting with the porch), type/brand metal roof in the northeast, tools ect.. needed to install metal? The underlayment is pretty darn solid. I plan on stripping the roof. One guy told me to insulate the roof with rigid insulation.......
Just unsure
Thanks in advance for the help
johnpma is offline   Reply With Quote
Old 12-06-2013, 04:05 PM   #2
Rewards Points: 634
If your thinking of an exposed fastener panel, don't waste your money. It's made for barns and should be left to them. Certain metal systems can be diy, perhaps a metal shingle roof on a simple building. Which system were you planning on using?
PatChap is offline   Reply With Quote
Old 12-06-2013, 07:20 PM   #3
Metal Roofing
Rewards Points: 600
Exactly what pitch is the "shallow pitch"?
Metal shingle type products, none that i know of infact, are allowed on low pitch. Knowing the pitch is going to dictate your product...this sounds like a standing seam will be needed to me. As Pat mentioned, the exposed fastener type metal panels will be a waste of time and $.
AndyWRS is offline   Reply With Quote
Old 12-09-2013, 02:09 PM   #4
Rewards Points: 93
Thanks for the input guys. It's what I was thinking. Screw down style roof. After your comments I'm thinking just plain ole asphalt again.....
The shallow pitch is maybe a 4/12....
Old 12-10-2013, 07:23 PM   #5
Lord of Slums
Rewards Points: 1,974
what type are the exposed fastener metal panels. Any links?
mj12 is offline   Reply With Quote
Old 12-10-2013, 09:47 PM   #6
Metal Roofing
Rewards Points: 600
That is actually good news, 4/12 is vertually going to allow you to select any of the metal roof options you want. Standing seam or metal shingles, both are gtg on 4/12.
I think the bigger issue will be $ and the skill set to install the product if your doing it yourself...some will require specific tools.
Old 12-11-2013, 08:01 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
R-Panel can be put down by most homeowners but Standing seam is a bit more advanced and does require some specialty tools as Andy mentioned.
Old 12-17-2013, 09:07 AM   #8
Rewards Points: 93
Thanks guys!! I know nothing about which metal roof to choose. I don't want to break the bank but want a quality DIY product. Have done many asphalt shingle roofs but it seems that many homes are going to metal in my area. I do see the screw down style roofs being installed on homes here.... how if R-panel installed??
Leaking Metal Roof debisans Roofing/Siding 1 10-23-2012 07:44 PM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 08:44 PM
Finished Attic with Metal Roof jonathan03 Remodeling 3 05-13-2010 06:50 AM
Metal Roof Estimate supton Off Topic 5 04-17-2010 04:08 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 01:18 AM
