Is This Job Roof Complete? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-19-2010, 05:48 PM   #1
Is this job roof complete?
Hi. I was just wondering if this is a proper finish on my roof before I bring it to the builder's attention. Thanks everone for the help.
betteroffdeaf is offline   Reply With Quote
Old 11-19-2010, 06:30 PM   #2
Uh, my guess would be no!
littlecleo is offline   Reply With Quote
Old 11-19-2010, 06:35 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what is the black material?
If it is an EPDM/rubber membrane, it might be complete as is. Due to the cupping action of the roof peaks on both sides, there may be a concern with setting water which a standard shingle roof will not prevent the water from running back under the material and wetting the roof sheathing.
Old 11-19-2010, 06:43 PM   #4
MJW
First thing you do is go punch the architect on that plan and tell him to take his job more seriously. I mean really???? That could have easily been avoided.
MJW is offline   Reply With Quote
Old 11-19-2010, 06:44 PM   #5
It's definitely not epdm but still may be fine. I would hope it is torch down or self adhered modified bitumen, in which case they probably saved you from a likely leak in the future (if that were shingled instead), NOT 90lb roll roofing with tar sealing the laps together, which will surely leak in the near future. A closer pic and it would be easy to tell.
You shouldn't feel bad about asking your builder what material was used there, if for no other reason than future maintenance needs.
jmiller is offline   Reply With Quote
Old 11-19-2010, 06:47 PM   #6
You sound like us at work every single day we deal with new construction.
Old 11-19-2010, 07:29 PM   #7
there was no architect _on_ that job. just some junior drafter who built the roof to fit the rooms that the plans were spec'd for. however, the firm that signed of on the plans should have done a better job in the review phase.
1910NE is offline   Reply With Quote
Old 11-19-2010, 08:44 PM   #8
MJW
Sorry to be negative, but these guys make me mad. Just because it can be drawn doesn't mean it can be constructed and actually work in real world conditions........especially with the normal "residential budget".
Old 11-19-2010, 09:19 PM   #9
Doing This Way Too Long
Rewards Points: 532
According to your roofer it's finished based on the details in the picture. Very good of them to run a membrane and not be an idiot and run shingles there but I'd advise you to definitely find out exactly what material was installed there and maybe post the info here.
MJW, I've been saying that for years.
OldNBroken is offline   Reply With Quote
Need some help with roof - NO clue what to do, or how.. :( AdrianVall Roofing/Siding 7 04-22-2010 09:32 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
how do you complete a roof rebuild(all by yourself) without it raining in??including 4just1don Roofing/Siding 1 11-11-2008 04:56 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
