James Hardie Install On Gable Ends - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-25-2013, 07:39 AM   #16
Tom Struble's Avatar
Rewards Points: 2,002
a drain wrap like this
http://www.benjaminobdyke.com/visito...t/key/hydrogap
Tom Struble is offline   Reply With Quote
Old 12-25-2013, 08:35 PM   #17
I'm also going to install a PVC skirt board. Would it be acceptable to install a 12" wide ice water shield on the bottom then skirt board,flashing, house wrap and siding??
joedward is offline   Reply With Quote
Old 12-26-2013, 06:05 AM   #18
won't hurt
Old 12-26-2013, 12:56 PM   #19
Registered User
Rewards Points: 526
Where are you located and what type of sheathing- OSB, plywood, any foam board in the mix?
Gary
Old 12-26-2013, 03:44 PM   #20
I Am located Athens, Georgia it will be installed on OSB sheathing no foam board. Only worried about water penatration because I currently have vinyl with no moisture barrier behind it so I am getting a lot of water damage on the back side of my sheetrock.
Old 12-26-2013, 09:19 PM   #21
Registered User
Rewards Points: 526
With your -50" of rainfall, http://average-rainfall.weatherdb.co...tlanta-Georgia
you need a drainable house wrap; https://docs.google.com/viewer?a=v&q...RvUBSlz4b5thmA
as Tom said, though that one only has 16perms. If you want to help dry OSB, get a dimpled/drainable that is higher than 28 perms to help it dry outward for your location;
http://repository.tamu.edu/bitstream...pdf?sequence=4
Gary
PS. The PVC skirt and sticky wrap are both vapor impermeable.
Old 12-26-2013, 09:38 PM   #22
Registered User
Rewards Points: 526
Further thoughts; with your high rainfall coupled with an engineered product (OSB) and a reservoir siding (fiber cement) have you thought about a "rainscreen" system? http://www.buildingscience.com/docum...gs?full_view=1
At least behind the PVC trim, 1/4" is all it takes to let it drain past the continuous contact top of each board; http://www.buildingscience.com/docum...term=hockey+pu
This would really be the best you could do for dry sheathing, and make sure the drainage plane includes new pan flashing for the windows/doors; http://www.buildingscience.com/docum...d-wall-systems
Gary
Old 12-28-2013, 06:36 PM   #23
Thanks Gary for the info a lot of good reading. Is it common practice for rain screens in your area? I have never seen any homes in my area done with a rain screen.
Old 12-28-2013, 06:39 PM   #24
What do most of you do for mounting blocks for lights, outlets,dryer vents ect? Do you make your own or purchase some type of mounting blocks?
Old 12-28-2013, 10:11 PM   #25
Registered User
Rewards Points: 526
Rainscreen walls are the norm (code required) in Canada, not so much around here (37" annual precip.) so don't need them as much....Tom S. is the one to ask on the light blocks, I usually make them, though I have trouble parting with $$. Lol.
Gary
Old 12-29-2013, 09:27 AM   #26
Mid-America has mounting block specifically for FC
http://www.midamericaworldwide.com/p...utility-vents/
but you can use the standard ones if you flash it properly
The Following User Says Thank You to Tom Struble For This Useful Post:
woodworkbykirk (12-29-2013)
Old 12-29-2013, 10:30 AM   #27
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
i pretty much do the same install method as tom. the mounting blocks work great. its too hard to try to hang lights off the siding itself and theres no guarentee it will stay in place
James Hardie Install on Gable ends-388485_10150591124854466_1910500944_n.jpg   James Hardie Install on Gable ends-azec5.jpg   James Hardie Install on Gable ends-384328_10150591122569466_1986303979_n.jpg   James Hardie Install on Gable ends-azec4.jpg
woodworkbykirk is offline   Reply With Quote
Old 12-29-2013, 11:53 AM   #28
OK thanks you guys!! Lots of good info. I will post some pics soon as I get started.
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 12:55 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
Hardie Panel install? vern96 Building & Construction 1 07-01-2008 06:03 AM
Attic gable fan install mattmcl HVAC 2 04-23-2008 09:26 PM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 10:50 PM
