James Hardie Install On Gable Ends - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-22-2013, 02:03 PM   #1
James Hardie Install on Gable ends
I am fixing to install James Hardie siding on my home. I was curious how some of you have installed the rake trim (trim between soffit and siding). I see some where it has been capped over the siding and some where it is cut close and butts to the trim. If anyone has pictures that would be great also.
Thanks in advance!!
joedward is offline   Reply With Quote
Old 12-22-2013, 02:10 PM   #2
Framing Contractor
Rewards Points: 98
Thanks in advance!!
You can not install the trim on top of the Hardi per their site. Install the trim first and leave 1/8" gap where the siding meets it. Then it gets caulked at the end. The Hardi site has the full instructions.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
woodworkbykirk (12-29-2013)
Old 12-22-2013, 02:15 PM   #3
Framing Contractor
Rewards Points: 98
You also could cut a rabbet into the edge of the trim and let that hide the joint. We have installed some corner boards this way.
Old 12-22-2013, 07:18 PM   #4
Ok thanks I had not even thought about a rabbet joint. Do you have any pictures you could share?? I have read the James Hardie best practice manual but it seems a little unclear on the proper technique for the rake trim.
Old 12-22-2013, 08:42 PM   #5
Framing Contractor
Rewards Points: 98
We are doing a Hardi shake job now. I will try to get a few pics tomorrow.
Old 12-23-2013, 08:58 AM   #6
ParagonEx's Avatar
Rewards Points: 150
If a rabbit is what I assume it is, it would be difficult for someone with a lot of experience to do. Install your rake trim first then install the hardie to the rake board leaving the recommended gap and caulk.
ParagonEx is offline   Reply With Quote
Old 12-23-2013, 02:26 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
all that caulking just becomes a maintenance problem over the years and does little to nothing to prevent water infiltration long term imo
run the siding to a 3/4'' packing and install a wider trim piece to cover over the top edge of the siding
James Hardie Install on Gable ends-img_0606_1_1.jpg   James Hardie Install on Gable ends-img_0612_1.jpg
Tom Struble is offline   Reply With Quote
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
joedward (12-23-2013), oh'mike (12-23-2013), woodworkbykirk (12-29-2013)
Old 12-23-2013, 10:41 PM   #8
Great pictures Tom!! Is this some of your work? If so you do excellent work. When you say "run the siding to a 3/4'' packing" So install first piece of trim 3/4" wide and butt siding to that and then cap over with like a 1x4 or 1x6 equivalent? Will this allow wasp and such an entry point?
Old 12-24-2013, 09:20 AM   #9
yes it's mine,and yes install the panel to a packing strip [for arguments sake]3/4''x3'' wide and cover that with a 1x4 so you create a pocket
as long as the wall is properly prepared while insects may nest in the pocket they won't be able to enter the house
Old 12-24-2013, 05:30 PM   #10
Ok thanks Tom. What type of material is the trim in the photos above? I am going to use PVC trim for mine I ran across a great deal on some made by Trex. Do you caulk the packing strip to siding before you cap over it? Would you use a pressure treated board for packing strip or just rip a piece of PVC ?
Old 12-24-2013, 07:16 PM   #11
you can caulk the siding to the packing,my philosophy is to paint all cuts on Hardie instead of caulk
the trim in the pics is mostly pine,i typically just use fir or spruce for packing
imo pvc is not always the best material when used in long lengths due to expansion/contraction issues and the limited colors it can be painted,i prefer Boral http://www.boralna.com/trim/trim.asp
i do use pvc where it's temperature sensitivity is not as much an issue like in window trim
James Hardie Install on Gable ends-0817031249.jpg   James Hardie Install on Gable ends-0818030848.jpg   James Hardie Install on Gable ends-0901031223c.jpg
The Following User Says Thank You to Tom Struble For This Useful Post:
joedward (12-24-2013)
Old 12-24-2013, 07:30 PM   #12
kwikfishron's Avatar
Rewards Points: 90
Good looking walls TS...WB!
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (12-24-2013)
Old 12-24-2013, 07:37 PM   #13
Registered User
Rewards Points: 4,924
Nice work, Tom! Any soffit venting or is it concealed?
Gary
PS. welcome back....
Old 12-24-2013, 07:45 PM   #14
it's actually behind the frieze board
thanks guys!
Gary in WA (12-26-2013)
Old 12-24-2013, 08:12 PM   #15
Appreciate the pictures Tom!! I will be starting on my home in a couple weeks I will try and post some pictures for everyone to see. Also which house wrap do you prefer to use the James Hardie brand or something like Tyvek ?
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 01:55 PM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
Hardie Panel install? vern96 Building & Construction 1 07-01-2008 07:03 AM
Attic gable fan install mattmcl HVAC 2 04-23-2008 10:26 PM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 11:50 PM
