J Channel - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-23-2013, 10:25 PM   #1
n2omichael's Avatar
Rewards Points: 115
J channel
We recently moved our small cottage onto poured foundation with a knee wall, the original cottage was covered in siding, we can't match the siding and don't want to reside the entire place, so we have decided to go with vertical siding that matches the soffits and trim. My question is does anyone make a double J channel to connect regular siding to vertical siding?
My
n2omichael is offline   Reply With Quote
Old 06-24-2013, 05:39 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
There are trim details called T and H channels but I don't personally care for them.
In a horizontal application, they fill up with goop and can be an issue.
I would trim it out via step flashing and regular J/starter trim.
Old 06-24-2013, 06:08 AM   #3
Rewards Points: 14,300
Where have you looked for this siding?
If you've only been to the box stores then your going to be limited to just a few choices.
Look up siding in the yellow pages, a real siding supply company is what you need.
It's rare when I can not match siding up.
Got a picture?
I also hate to see H molding used when someone is adding an addition or doing something like enclosing a garage door, looks to DIY to me.
Old 06-25-2013, 12:36 PM   #4
n2omichael's Avatar
Rewards Points: 115
I can provide a pic, not sure how to post pics here? The siding is probably 40 years old, wouldn't new stuff look different since it hasn't had sun and weather for 40 years? Thoughts?
Thanks Guys!
Michael
Door bottom channel selection question SM05 Windows and Doors 8 06-25-2013 07:25 AM
Istalling a storm door with j channel instead of brickmold Bigman610 Windows and Doors 1 09-20-2012 05:14 PM
Help! Casings around window with integrated J channel? Learn2Build Remodeling 8 06-01-2010 05:10 PM
How-To: cut a channel in concrete? vsheetz Building & Construction 7 01-31-2009 01:21 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
