Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-23-2007, 10:48 PM   #1
Question
I've got a leak!! What to do?
Ok, I have a 1.5 story house with two dormers. One on each side. The roof on said house is pretty old. I actually don't know how old, but it's got to be 20+ years old. The valleys on the dormers are leaking. Pretty bad actually. I've been calling various roofers about repairing the valleys, but most of them don't want to touch it because the rest of the roof is so old, they feel like it would be asking for problems.
So... I'm guessing a need a new roof. It's gonna be a tear-off/reroof. But I can't afford it until this fall. Anything I can do as a stopgap in the mean time?
I'm envisioning a bucket of tar and a big brush, but I'm hoping someone has a better idea.
Thanks.
elitts is offline   Reply With Quote
Old 05-23-2007, 11:03 PM   #2
Super Moderator
The only thing that can be done on an old and crumbly roof is to tarp the area, using a tarp large enough to stretch beyond fromwhere the bottom of the valley is and run vertically up to the ridge of the dormer on the one side of the valley and up to the ridge of the main roof on the other side of the valley.
Since the tarps will be in place for a long time, buy the heavier density weave tarps which cost more, but won't disintegrate from the suns UV rays as quickly. Nail 2" x 4"s on the vertical perimeter edges and horizontally across the ridges with on nailed or screwed at the top of the valley, but dont nail that board any lower in the valley or it will cause more leaks.
The boards are to secure the tarp during the winds and to prevent billowing.
Alternatively, you could try to have a roofer apply a torch dowm APP modified bitumen over each valley and see if that seals tightly enough to the existing shingles to prevent significant water intrusion.
Any patch job done on the top of the shingles, is just temporary, at best.
Whatever you do, do not pour asphalt emulsion or plastic roofing cement over the valley, as it will dry up and when it cracks, it will be bonded to the existing shingles and further intensify the existing leakage. Plus, then you will have a hard time getting any roofer to even want to work on that gunky mess.
Ed
Ed the Roofer is offline   Reply With Quote
HVAC/Comfortmaker leak problem notsogoodwrench HVAC 8 08-09-2007 10:59 AM
Central heat and air unit leak ? bdalekid HVAC 1 03-21-2007 08:31 AM
pipe leak & sheetrock damage santogr General Discussion 2 03-04-2007 02:44 PM
Minute Gas leak rjordan392 Plumbing 3 11-12-2006 11:59 AM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 10:13 AM
