Interlock/T-lock Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-11-2010, 10:51 PM   #1
Rewards Points: 18
Interlock/T-lock shingles
I can't find anything of real value on how to install interlock shingles. Can anyone help?
Schmidty is offline   Reply With Quote
Old 07-12-2010, 12:41 PM   #2
Rewards Points: 83
Yeah there isn't too much info on installing T-Locs, although they are rather easy. IKO has a PDF for installing their Armour Lock shingle, not very in depth though.
bcdemon is offline   Reply With Quote
Old 07-12-2010, 02:12 PM   #3
Rewards Points: 18
One question?
Do I snap a line from the middle of the fascia board to the middle of the peek and work from that center line out or do I start on one side or the other?
I hope my question makes sense.
Old 07-12-2010, 07:15 PM   #4
Rewards Points: 83
Start in the middle. You don't have to find dead center, but you should draw a chalk line. Just somewhere close to the center. So pick your starting area, then work off one side, I would run out your starter and first row to the end of the roof, then do the same on the other side, then again from the middle, start your next row.
Just curious but, why did you go with T-Locs and not a laminated shingles like GAF Timberline or Certainteed landmark?
Old 07-13-2010, 12:42 AM   #5
Rewards Points: 18
My house was built in 2001 and T-lock were still being used. The t-locks are the exact match to the ones on the rest of the house. Thanks for the help.
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 08:46 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing/Siding 4 02-03-2010 03:21 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
