Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-24-2010, 10:24 PM   #1
Question
interior walls sweating
I have a split level home that I've recently purchased. There is no leak, plumbing, air ducts or anything like that in my attic and my hallway walls are sweating bad. Happening right @ the hottest time of day and it seems to be alot of heat escaping around my attic access in hallway. I have gable vents and soffit vents but none of the things on house that spin around(don't know what they are called). Do yall think that this is a ventilation problem or something else? Got 2 get it fixed!!
jbm#13 is offline   Reply With Quote
Old 05-24-2010, 11:17 PM   #2
Definetly venting issue, if its happening at hotest time of day, is your house got a/c, the warmer the air the more moisture it can hold when the warmer air meets with colder air it cause the warmer air to drop its moisture ie condensation. Look for two things plugged attic venting at soffits, your insulation may be covering your soffit vents or animals nesting in roof vents are another source.
mark2007 is offline   Reply With Quote
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 10:06 PM
Sweating With Water In Line BOUTYM Plumbing 13 02-03-2010 09:33 PM
Sweating toilet tank Tekno9000 Plumbing 6 01-30-2010 02:22 PM
Sweating interior walls mhpruitt727 General Discussion 16 12-28-2009 10:22 AM
The "ART" of sweating copper Joe F Plumbing 5 07-01-2008 12:55 AM
