Insulation "stuck" Near Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-07-2012, 11:28 AM   #1
Rewards Points: 16
Insulation "stuck" near soffit
All,
(excuse my ignorance)
It would seem that the builders or previous owners decided to put insulation (roll not spray) in between the soffit and the main opening in the attic thus not allowing any airflow from the soffit. I tried to remove the insulation but, it seems to be stuck, I believe trying to push/pull + nails + backing is making it darn near impossible to remove. The gradient of the roof makes it increadibly difficult to get near it to push/pull. I tried going from both angles (from soffit and attic) and made it worse.
Are there any tricks to remove the insulation?
Thanks,
Randy
tathamr is offline   Reply With Quote
Old 07-07-2012, 07:13 PM   #2
DIY staff
Rewards Points: 7,174
Would it be possible to slip a 14" wide piece of Masonite or plastic between the roof sheeting and the insulation and compress it enough to slip in a foam air baffle?
Old 07-08-2012, 08:54 AM   #3
Rewards Points: 140
can you use one of these, the one at the front/angle. to reach in there are pull some out.
Fix'n it is offline   Reply With Quote
Old 07-08-2012, 09:12 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
+1 to the rake/hook idea.
Going to be tough with roofing nails coming through but time and some patience will get it done.
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 11:04 AM
Removing Insulation from Soffit Vents cpfoutz Roofing/Siding 18 01-03-2012 10:35 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
