Insulation In Roof Rafters At The Gable End - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-08-2010, 09:34 PM   #1
Insulation in roof rafters at the gable end
Hi guys, I'm in the process of insulating my roof rafters and I'm not sure what to do at one of my gable ends. The gap between the last rafter and the gable end is quite a bit larger than the standard 16" which the rest of the rafters are spaced at. here's a pic to help illustrate:
I'm thinking I can just throw in another set of rafters and a collar tie at one more spacing of 16". That way I'll have something to attach vapour barrier/drywall to closer to the gable end and also my last row of insulation will fit much nicer between the new rafter and the gable end. Would this be a good idea? Is there an easier solution?
Thanks!
nofx1981 is offline   Reply With Quote
Old 03-09-2010, 08:57 AM   #2
jlhaslip's Avatar
Rewards Points: 2,196
would a bag of 24" wide insulation work?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-09-2010, 09:00 AM   #3
Commercial Roofing
AaronB's Avatar
I would go with your original idea.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-09-2010, 11:48 AM   #4
Yeah, I think it probably would, haven't measured it yet. But then i'm still left with nothing near the gable to attach my vapour barrier or drywall to? which I don't like... I could maybe nail 2x4's against the gable wall studs for a drywall/vapour barrier nailing surface?
Yeah I'm thinking that's prolly the best way to do it too, unless someone gives me a reason otherwise.
Old 03-09-2010, 03:20 PM   #5
Commercial Roofing
AaronB's Avatar
Are you finishing this space?
Foam insulation would serve you much better for this configuration.
Old 03-09-2010, 03:21 PM   #6
Commercial Roofing
AaronB's Avatar
You know whats funny about insulation and vapor retarders???
Theyre supposed to be on the warm side, but the warm side changes from winter to summer.
sloped roof insulation imtryingtofixit Roofing/Siding 10 04-01-2010 07:52 PM
Help with roof/ceiling insulation jake61 Building & Construction 0 12-06-2009 07:18 AM
Gable fan? Powered roof vent? idahojoec Roofing/Siding 2 07-25-2009 02:06 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
tin roof insulation 1870Colonial Roofing/Siding 5 11-21-2007 06:21 AM
