Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-21-2011, 11:14 AM   #1
Insulation options for 2"X4" roof framing
I am getting ready to re-sheet the roof on a home I own that has 2"X4" roof framing with the sheet rock screwed to the bottom side of the 2"X4". Currently it is insulated with pink R-11 but it packs the entire bay and leaves no room for air flow. As I am going to have access to the bays when I have the sheeting off I would like to replace the insulation with something thinner so the air can flow but all the thinner foam insulation at home depo has R values in the R-8 or lower range. Is there a better option out there? I am going to sheet with Norbord Solarboard OSB so the heat should not be a big problem but would still like the R value for the cold
Dave
Dave K is offline   Reply With Quote
Old 04-21-2011, 12:59 PM   #2
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Install rafter baffles over the fiberglass to ensure there is air flow beneath the sheathing. You could also install spray foam, making sure to leave an 3/4" air gap between the top of the insulation and sheathing for ventilation.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 04-23-2011, 11:54 AM   #3
mem
The baffles are a good idea to ensure air flow but they will probably compress the pink and therefore reduce it's R value--possibly to eight or even less. Best bet might be to fur the rafters with 2x2s and then install the baffles for ventilation.
mem is offline   Reply With Quote
Old 04-24-2011, 01:18 PM   #4
Moderator
The Solarboard needs an airspace below it to be effective, 3/4", I believe. If you live in a mixed heating/cooling climate or just a cooling climate, it is effective. Not in a heating climate, the added insulation would be better. You need the solar gain in the attic to reduce the load on your furnace in Winter. I would use an unvented design with shingles rated for "no venting", using the saved money from S.B. on shingles for the warranty; http://www.buildingscience.com/docum...r-all-climates Still need to isolate sloped ceiling from other attics with foam board.
You may still need to add furring for insulation as said, depending on your location. Where are you located?
Gary
Clothes taking longer to dry?
Old 04-24-2011, 09:01 PM   #5
I am in Northern California. The weather here is mild with temps rarely hitting freezing in the winter almost never over 100 in the summer. Keeping cool in the summer my biggest concern as we almost never need to turn the heater on in the winter. I think I am going to fur the rafters with 2"X4"s turned on there side. Should I go to R-19 with baffles or just stick with the existing R-11?
Thanks for the help
Dave
Old 04-24-2011, 09:55 PM   #6
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Ooh, in California, you let the cat out of the bag there.
You need:
1. A permit.
2. A"cool roof" or "radiant barrier sheeting".
3. Probably R-30 insulation of some sort, whether by furring out the roof rafters or some other method.
4. California Energy Standards Calculations, ie. use the "prescriptive" approach or the computer calcs.
5. A set of plans.
IF, you want to be legal and above board.
Not necessarily in that order.
Andy.
AndyGump is online now   Reply With Quote
Old 04-24-2011, 10:03 PM   #7
My local building department is not all that bad. Just a $160 roofing permit and I can go about my business. The inspector comes out to check my nailing on the sheeting and then again to check off my shingles.
Old 04-24-2011, 10:12 PM   #8
old guy contractor
tcleve4911's Avatar
A 2x4 roof system is best served with spray foam insulation, no venting.
This will give you the highest R value, zero condensation and it actually adds structural integrity.
tcleve4911 is offline   Reply With Quote
Old 04-24-2011, 11:05 PM   #9
AndyGump's Avatar
Hi Dave, I didn't think there was any place like that left in California. LOL
A couple years ago I did some plans for a guy in Placerville, He thought that the permitting agency was really lax on requirements too. Ended up having to do all the basic stuff required in California like Energy Standards including electrical, heating, cooling, etc.
You see a lot of people do not realize that all of CA. is under the new CBC, all cities, counties etc. have to adhere to the codes including the Energy Standards, big PITA I know. So unless you are just re-roofing and not tearing out the existing sheathing then you can get by with maybe just a re-roof permit, but once you open the envelope of the building you are required to do the full compliance thing.
Anyway just letting you know, please let us know how it goes with your project. Thanks.
I wonder if Nathan would let me blog on this subject?
Andy.
Old 04-25-2011, 12:07 AM   #10
I only talked to the lady at the front desk and not the building inspector because he works alternating days so there is a chance that she miss-led me. I am going to hope for the best. My last project in Ca cost me $12000 in permit fees just for a small addition not to mention going through design review and all the other BS that goes with building in Ca
Old 04-25-2011, 12:42 AM   #11
AndyGump's Avatar
12k?! That's out of line even here in the Olde Town Historic District of Orange.
I am stunned.
Andy.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Best way to replace/insulate a flat tar-gravel roof Hexar Roofing 19 10-08-2010 01:17 AM
Flat roof and insulation quandry paredown Roofing 2 08-21-2010 12:50 AM
New Roof and Insulation over Existing Roof MitchellScott Roofing 1 05-03-2009 09:24 AM
Flat Roof Suggestion gladiator Roofing 3 09-14-2005 04:31 PM
